capacitor to MGM16018.
masense
capacitor to MGM16018. - 11.07.2008, 07:52 AM
I want to add capacitor to MGM16018.
What do you do?
I ask for good advice.
MGM 16018
3s×2p 6s 5200
xt8
1515 2200KV
12/48T
MGM 16018
9s a123 or 8s 4000
MUGGY
1521 1900KV
11/46T
Is low esr capacitors a value of how much?
Are you usable to MGM 16018?
1,500μF 105℃ 0.014ΩMAX. 35v
11.07.2008, 09:49 AM
Question about your signature- you said you run a 16018 on 8s lipo. The 16018 has problems with 6s and runs comfortably on 5s. Are you sure you're not mistyping something?
Finnster
KillaHurtz
Finnster's Avatar
11.07.2008, 12:17 PM
That's too many volts for the 16018. You need a 9032 or a 16024 to run that high of voltage.
I don't know how much value putting more caps on would be. They are already quite large and the esc runs well, at least my 9032 does upto 10S.
bdebde
That's All Folks!
bdebde's Avatar
11.07.2008, 04:15 PM
The MGM's only need additional caps if running very long battery wires. But as the others said a 16018 will not do 8s (6s max).
masense
11.07.2008, 06:12 PM
sory! sory!
mistyping^^
MGM 16024
9s a123 or 8s 4000
MUGGY
1521 1900KV
11/46T
16024 9s a123 very nice
my xt8
I do not want to lower the pinion more than this.
I want to lower the temperature of some ESC.
There are two fans.
Motor and ESC are expensive!
It is already 16018× 2.
16024× 1. I stand.
I bought TEKNO v3 RC8 1515 2.5.
I am not more than enough a fund.
13/48T 70℃ by this run.
MGM USB+ PC max temp
13/48T
now12/48T 60℃ over
Is not there a good method to lower temperature?
I have not used CAP.
I think whether some temperature are lowered and demand advice from all of you.
e-mike
e-mike's Avatar
11.07.2008, 06:35 PM
cut your front window....maybe could be helpfull
D8t on juice!!
Lucariel
Italian Brushless Style
11.07.2008, 06:36 PM
this is very good notice... if the mgm 16025 run with 8s A123 is really the definitive esc......
you run in configuration 1p or 2p???? ware is the autonomy???
masense
11.07.2008, 06:52 PM
I have tested it in a123 4s2p.
EOS0610iDUO90% charge.
When the voltage of A123 falls, I am usable in 8s.
However, 16018 A123 is until 7s.
I think that I am broken as run possibility immediately.
Because I am heavy, A123 does not stimulate 2p.
VID 1p.
now xt8 3s2p 5200 lipo.
12/48T
1515 2200KV
Only window 1/3 open now.
I open it fully.
try try try
In the case of 16018.
Does not the capacitor addition come for chilling effect expectation?
