3s 6000mah Maxamps with 1 bad cell...
saucisse
saucisse's Avatar
3s 6000mah Maxamps with 1 bad cell... - 11.07.2008, 01:21 PM
Would you take the pack appart, find the faulty cell and remove it to use the pack as a 2s or just get rid of it?
____________________________________________
I don't suffer from insanity, I enjoy every minute of it !!
11.07.2008, 01:26 PM
A 3s maxamps 6000 packs actually has 6 3000 cells in there. 3 pairs of 2 cells are wirred in parallel to give the 6000 rating and those pairs are then wired in series to make 3s.
My experience is that 2 of the 6 cells are bad, one most likely puffed and killed the cell that was wired in parallel to it. You can take the pack apart and make a 2s pack out of it, but maxamps resistance welds/crimps their tabs together and they are difficult to work with. The taps are very fragile, and tear off easily. Have a look at the link in my signature below for more lipo info. I have repaired and reconfigured many maxamps packs, due to cell death....
saucisse
saucisse's Avatar
11.07.2008, 01:56 PM
Thanks for the heads up !
11.07.2008, 02:00 PM
No problem, if you need any help just send me a message...
CrazyCooydog
11.07.2008, 11:36 PM
Been here a couple of times
Be very carefull.
