Hyperion EOS0610i Net Question
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Hyperion EOS0610i Net Question - 11.18.2008, 06:27 AM
Recently bought a new Hyperion EOS 0610i Net Charger. While charging it has never got to 100% full charge. Gets to about 97% and then comes up with BLC. Does this mean the Balancing doesn't start till 97% charge. What does everyone set their TCS to. I get sick of waiting for 100% TCS?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
bl-is-future
bl-is-future's Avatar
11.18.2008, 09:40 AM
mine does this every once in a while. It is something with the balancer. I freaked out one day and immediately unplugged the battery and test each individual cell with my multi meter and none were low nor high. So i plugged it back in and the charger finished it no problem. Also on my trakpower packs i have to start the charge with the balancing OFF then once it is charging plug the balancer connections in and will be fine. Other wise it will say battery connection error. Cant remember the acronym but that is what the error means. Also i found if it glitches out just remove all power to the charger and let it sit a minute then try it again.
George16
Supermaxx
George16's Avatar
11.18.2008, 10:48 AM
I set mine to 100% TCS. The only problem I had before was due to the power supply not providing enough amperage(MRC 977 power supply). No problem after I start using a 20A power supply (Pro-peak).
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
DRIFT_BUGGY
11.18.2008, 04:17 PM
I think it is a 10A power supply (cant remember) but it can charge at 5 amps no worrys just when it goes to 97% TCS is comes up saying BLC and starts chargering a .3Amp or something
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
11.18.2008, 05:03 PM
A 10A supply running at a constant 12v can only supply 120w. Chargers are around 80% efficient, so that is only 96w available for the cells. At 4s 5A, that is reaching the limit (84w). However, at 10A, the supply output voltage is probably dropping. So, if it hits, say 11v, that limits your charge level even more.
And it makes sense that it does this towards the CC/CV threshold since the power requirements are highest then.
That said, I have an old Hyperion EOS7i which displays a different error message ("voltage too high") near the CC/CV threshold when charging lipos at anything above 3.8A. I can charge at whatever current, but when the voltage gets to ~4.0v/cell, I have to drop the charge current to 3.8A. But in my case, it is a charger defect. Works fine at high currents with NiMHs though, so it is indeed a defect. You charger may simply have a similar defect.
DRIFT_BUGGY
11.19.2008, 12:59 AM
But the battery should be right to take off at 99% TCS and use or is it best to leave it?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
11.19.2008, 04:07 AM
Ended up working out that the TCS when completed was set out continue instead of end. So the 10A power supply seems to be fine after all
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
11.19.2008, 07:43 AM
fyi i set mine @ 95%. doesnt seem to make much of a difference, and all the cells are within 0.002v of each other without balancing... why bother waiting for nothing!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
