"Powerizer Batteries", with capacitors?
JThiessen
JThiessen's Avatar
"Powerizer Batteries", with capacitors? - 12.04.2005, 01:58 AM
Anybody ever use these?
Powerizer
I've never seen a battery in an RC with a capacitor on it! The batt's from them are generally low price - gotta wonder about quality. But then, one never knows until you try em.
E-Traxxer
12.04.2005, 03:17 AM
They have 30 amp discharge, and for $40 for 14 cells, I'd say that's a heck of a deal!
tyrewq
12.04.2005, 03:21 AM
i know that capacitors store charge but how do they actually perform in that setup? has anyone tried these yet? or know how much charge was stored in the capacitors?
Serum
Serum's Avatar
12.04.2005, 04:40 AM
They can take some peaks from the currentdraw, but it depends on the quality of the caps how much current they can handle.
And the 2nd thing is that those caps are only able to absorb the smallest peaks, because they wil be empty pretty soon..
The reason for using caps on an esc serves a whole different purpose. (to protect the batteries from being puls loaded)
MetalMan
MetalMan's Avatar
12.04.2005, 12:07 PM
Those batteries are cheap. It would be best to save up your money and get better cells (GP3300 minimum).
CrazyPhantom
12.04.2005, 03:23 PM
Remember, you get what you pay for. Buy cheap, you get cheap quality ;)
coolhandcountry
coolhandcountry's Avatar
12.04.2005, 03:43 PM
The gp 3300s are a much better battery. I have bought and tried these batteries out. I have even broke them up and put them in bigger packs. They will run a truck but it is not the best battery on the market. If you don't have no batts and need some they ok. I would rather run the gp or ibc batts. IMO
Peace!
Country
Help support the
Rc-Monster
Buy here
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
12.04.2005, 05:00 PM
some1 here helped me learn that!
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
12.05.2005, 08:32 AM
I wouldn't bother with those...and the caps won't make any difference in performance...they aren't big enough. For power caps to make any real difference, you really need at least 10,000uF capacity on them (they look to be around 1,500uF). The idea is that they store up charge and release it when the ESC needs it most, keeping voltage up a little better and ironing out ripples. It certainly helps in high-current situations, but with such small caps you won't notice a difference. I have two 15,000uF power caps in parallel on Cold Fusion (effectively 30,000uF, and she is running twin 14T brushed motors)...it definitely aids acceleration a little and prevents glitching. Also, the cells stay a little cooler...not much, but every little helps.
As for the batteries themselves, well like you all say, you get what you pay for...
nbcaznmaster
12.05.2005, 03:55 PM
could u use caps on lipos?
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Nitro Revo - .18tm
MetalMan
MetalMan's Avatar
12.05.2005, 07:03 PM
You can use capacitors on any electrical source. Their effectiveness is determined by the "capacity" (Farad) of the capacitor.
tyrewq
12.05.2005, 07:57 PM
what's the optimum capacitor rating to snap into a 14 cell(1.2v each)? what's the uF and voltage? if you're using it on a monster truck with 99 amp draw
MetalMan
MetalMan's Avatar
12.05.2005, 08:16 PM
You would need a rather large capacitor for there to be a noticeable effect. You would need something with a 35v rating (to be on the safe side), and at least ~6000uf. But that would be a HUGE capacitor!
nbcaznmaster
12.05.2005, 08:22 PM
lol, not worth it huh?
LSP-R - Picco .26
Nitro Revo - .18tm
tyrewq
12.05.2005, 08:23 PM
it's weird. i see so many capacitors on ebay with small uf but big voltage
example:
http://cgi.ebay.com/5-CAPACITORS-470...QQcmdZViewItem
