CC 6.5mm bullets vs 4mm bullets -
12.02.2008, 02:50 PM
Will i see any noticeable gains by replacing the 4mm bullets that came on my teckno Neu to 6.5mm CC ones? I figured that since the 4mm ones came on the motor they should be enough but if it is advantageous to use the larger ones then i will most likely switch them out eventually.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
