OFNA Mutilator
mikey84
OFNA Mutilator - 12.03.2008, 02:30 AM
just wondering if anyone knows if theres a bl conversion mount for the OFNA Mutilator or if there is something that would fit it?
thanks, mike
Mutilator brushless
GREYGHOST
Mutilator brushless - 01.06.2009, 03:09 PM
I'd like to know if this is doable also.I know the muti is not very popular here,but for a basher,it looks o.k. .........anyone?
Semi Pro
Semi Pro's Avatar
01.06.2009, 04:56 PM
you need the center diff braces from the x1 cr and mikes motor mount for the cr
i can find the part numbers for you guys if you need them
here is a link to the motor mount you need
http://www.rc-monster.com/proddetail...CMcrbuggymount
dirt101
dirt101's Avatar
01.06.2009, 05:14 PM
I was thinking he could just use the CRT mount. would it not be the same?
rustler, lx2e, xxt cr
GREYGHOST
Thumbs up 01.06.2009, 09:58 PM
Sooo... anyone know for sure? I hate to just throw money at it just guessing.Guess I will do the measuring ,..if anyone has the above mentioned truggy's and could check the screw hole distance,it surley would help.
Semi Pro
Semi Pro's Avatar
01.06.2009, 11:19 PM
im not guessing, thats what i helped mikey84 put in his.
i think the spaceing is diffrent on the crt
Mutilator
GREYGHOST
Mutilator - 01.07.2009, 12:27 AM
O.k,great,thanks semipro.I'll give it a shot.I knew I could count on you guys.
Jesse M
Jesse M's Avatar
08.06.2009, 02:28 PM
Actually, the Hyper mount does not work for the Mutilator. I have them both sitting in front of me. The hole spacing is different. Props to whoever said it fits.
Jammin CR Mount with Mutilator does not work
Jesse M
Jesse M's Avatar
Jammin CR Mount with Mutilator does not work - 08.14.2009, 04:05 PM
Just got the CR motor mount at RCM and it seems as though it does not work with the Mutilator. Even if I got the Jammin CR buggy center diff braces, which you need to mount the RCM mount to the chassis unless you have some sort of 1/4'' spacer, the Mutilator spur gear would still hover over the top of the RCM mount by about 5mm so you would not be able to mount the center diff plate. Then a spacer for the RCM mount and the front diff mount would be needed to clear the 62 tooth spur gear. I would also need to dremel the bottom of the chassis to allow the spur gear to fit since its being lowered about 1/4'' from its stock position.
Any help is appreciated, especially documented visual footage of the conversion.
I almost feel like getting the CRT mount and rigging it up somehow because the CRT X1 also uses a 62 tooth spur gear I believe, so clearance top and bottom wouldn't be an issue. I may post pics later of the attempted conversion to show incompatabilities.
Jammin CR mount/Mutilator
Jesse M
Jesse M's Avatar
Jammin CR mount/Mutilator - 08.14.2009, 11:00 PM
Name:	cr mount 001.jpg
ID:	7553   Click image for larger version
Name:	cr mount 005.jpg
ID:	7554   Click image for larger version
Name:	cr mount 006.jpg
Name:	cr mount 003.jpg
08.15.2009, 09:18 AM
I know of nothing that will cope with a 62T spur without some work. The CR is a buggy mount and hence is looking for a 44-48T spur - The CRT is more suitable a designed for a larger spur but again the CRT as you point out has the chassis cut out.
The key thing is do the wholes line up - It is pretty easy to change the spur to something smaller and adjust the gearing accordingly.
Failing that it might be easier to use something that uses the nitro motor mounting holes.
http://www.impaktrc.com/product_info...oducts_id=4256
Freakycrawler
08.15.2009, 11:47 AM
milled my own but ist a screw on plate and not a plate that replaces the stock diff holders. But it works fine.
Dont drive my mutilator anymore though since i got my Hyper st pro
Jesse M
Jesse M's Avatar
08.15.2009, 01:20 PM
I tried putting a jammin buggy spur gear (50 tooth i believe) on the mutilator diff cup and the diff cup is a hair too big. I don't know of a smaller spur that would fit on the mutilator diff housing. I called ofna a while back and they said the jammin cr and crt spurs will not fit. I'm probably going to just dremel the chassis a bit and rig some sort of spacers for the top so I can use the top diff plate to clear the spur.
RCM CRT mount
Jesse M
Jesse M's Avatar
RCM CRT mount - 08.28.2009, 03:42 PM
CRT mount works flawlessly with Mutilator 62T. Direct drop-in, no mods necessary.
