Motor help for my Rustler
Snowman 78
5,280 feet above sea level
Snowman 78's Avatar
Motor help for my Rustler - 12.11.2008, 12:15 AM
Trying to decide witch motor for my Rustler
Stock Rustler
CC Sidewinder ESC
I will run it on 2 cell lipo & 8 cell NIMH
1. Feigao 380L (6L-4817kv or 8L-3613kv)
or
2. Traxxas Velenion 3500 Brushless Motor (3500kv)
Thanks
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
12.11.2008, 12:41 AM
Get a medusa 36-50-4800.
Snowman 78
Snowman 78's Avatar
12.11.2008, 12:50 AM
I can get a good deal @ my LHS on the Feigao or Velenion
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
jayjay283
jayjay283's Avatar
12.11.2008, 02:47 AM
I run a velineon in a rustler, 3500 kv (duh) on 3s and its fast, faster than it needs to be. On 2s its cool but leaves you wanting more. I run a 4800 kv (pretty sure) losi motor in a speet T on 3s, and that truck actually catches air. 4800 kv on 3s is turd smiling fun on 2s is sweet too and controllable. I vote the feigao 6l
trev3813
Dsm needed
trev3813's Avatar
12.11.2008, 06:12 PM
Nice sled in yer avatar, as for motor, they ( ^^^^) know what there talking about, listen to them.
snellemin
2 KiloWatt RACER
snellemin's Avatar
12.11.2008, 06:27 PM
I've used the 380c 6L and 4800 Medusa, and I prefer the Feigao in the Rustler still. Other then the Medusa running cooler and being cheap, I just don't see what the big deal is about.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
12.11.2008, 06:39 PM
...Other then the Medusa running cooler and being cheap, I just don't see what the big deal is about.
lol, are you serious? Those are pretty good reasons to me. Running the same power levels yet cooler means higher efficiency, which means more of your battery power is getting to the ground instead of being dissipated into the air. And the cheap part, well, that's a good thing too.
Snowman 78
Snowman 78's Avatar
Thanks for the advice
Sled is a 2003 Pro X with rail exten to 136 & a RMK 700 motor.
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
snellemin
2 KiloWatt RACER
snellemin's Avatar
12.11.2008, 07:12 PM
Ya I'm serious.
I've used both motors in the Rustler and for the life of me could not tell a difference in power. I'm not trying to be snob, but I'm just posting what I've experienced. I agree that less heat equals greater efficiency, but in the Rustler the cheaper 2 poler wins over the 4 pole medusa in my book.
trev3813
Dsm needed
trev3813's Avatar
12.12.2008, 02:51 PM
Nice, i got an old citation, but i love it.
chilledoutuk
12.12.2008, 02:58 PM
Ya I'm serious.
Just out of interest snellemin what timing settings have you run and have you tried gearing the motor for a higher top speed as from what i have read that tends to get the best out of 4 pole motors.
Also i would be interested in what controllers you have tried the Medusa motor on.
snellemin
2 KiloWatt RACER
snellemin's Avatar
12.12.2008, 04:36 PM
Biggest gearing I used was 58/25 mod .8. Lutach 200A speed controller set to 16khz, medium timing. I didn't bother with the mamba max yet. I did run the motor up to 6s1p A123 though and snapped a dogbone.
The feigao just spools up quicker then the medusa does.
chilledoutuk
12.12.2008, 05:31 PM
have you considered there 28mm motors with an adapter plate as technically they would then have the same small diameter rotor and have a faster spoolup with battery's that have limited current output like running 1s a123.
snellemin
2 KiloWatt RACER
snellemin's Avatar
12.12.2008, 06:38 PM
I'm not planning to buy any more medusa motors for 1/10 scale vehicles.
The most power hungry motor I have used so far in the Rustler are the LRP 3.5 and the Lutach Special 2.5T. The 3.5T was pulling 122.11Amps@6.21V continuous with a 3s1p A123 pack. The 2.5T was pulling 145A@7V continuous with 3s2p A123 pack. I see no need to go with lipo's yet.
Other fun motors in the rustler were, 8L c40 hacker, 5300+4200 basic lehner, 8T 540 Feigao motor, 7T nemesis/feigao motor, 3100xl lehner, 7T+8T 380c feigao, 9T+12T c40 hacker. When I went overboard with voltage w/the Rustler the B50 11L Hacker was hella fun. All ran with the A123's.
