Has anyone checked to see what the amp draw is like on this combo? or on a similar nue motor? looking to run 4s in an E-revo geared for around 40mph.
phil
Too many variables to make a good estimate. I've seen 120amp spikes typically though with the typical neu setups, so something in that region would be about right; your batts will need to support 100amps continuous minimum at any rate...
