Hi, I'm working on a Rimfire 35-36-1000 outrunner. In the process of centering the shaft so it can drive off both ends, the end piece that holds the shaft came loose from the magnet housing. Does anyone know what kind of glue I should use to put it back on?(yes it was glued on) I was thinking J-B Weld. Thanks, Don
JB Weld is what I used on one of my motors, and it's held up fine. Just make sure not to use too much (but use enough) and wipe off the excess so you don't ruin the balance of the magnet housing.
