what lipo's are you using in your revo?
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
what lipo's are you using in your revo? - 01.06.2009, 05:06 AM
can you just post the following (and comments)
brand
C rating
burst rating
capacity
cell number
how many (like 2x 3s = 6s etc)
runtime aprox (race conditions are better if u have them)
eagle tree data is very much apreciated if u have it ;)
i'm trying to chose some good batts...i know this much...
maxamps...suck
venom = ok
zippy-H are pretty good
rhino is the same as zippy but something fishy there
few other brands are good but i'm looking at cheapies ;)
shaun
  Send a message via MSN to shaunjohnson
azjc
01.06.2009, 07:15 AM
I run a pair of Flightpower EVO 25c 5s 3700 packs, I also believe that Venoms suck, and if you buy Zippys I prefer the "R" cells over the "H"s
Semi Pro
Semi Pro's Avatar
01.06.2009, 02:03 PM
maxamps 35c 4200mah 5cell 1p
alot of people hate maxamps but i have had great luck with their packs, i picked this pack because of size and weight, my truck is only used for racing, i get 20-25 min of run time depending on my gearing and track conditions, the pack never gets warm
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.06.2009, 05:34 PM
I'm running a MMM with a TeknoNeu 1515 2.5d
5s=18.5V
NeuEnergy 25C/50C 4900Mah 2s on motor side and 3s on esc side
20+minute screwing around, bashing race style
5s MaxAmps 20C/40C 5000mah 2s motor side/3s esc side
aprox 20 minutes screwing around, bashing race style
Current gearing is 62/20 = about 35MPH on Badlands
My idea of bashing race style is following a course in my apt parkinglot. Just make up a course using stains in the blacktop, generally a few short runs with turns and a long straight away, similar to an actual race course. Yes I'm still running MA packs, I sent in to messed up 2s packs and they sent me what I wanted in return so I can't hate on them to much. The Neu packs have more punch with out a doubt. Temps on everything are great at the end of a 20 minute run with either set of packs.
tedo
Vermont, USA
tedo's Avatar
01.06.2009, 06:41 PM
I run all 2s 8000 packs
4 MA 8000's (20C)
2 True Rc 8000's (15C)
I tell you I have never had a problem with either brand.
Never have seen over 100 degrees F and geared for 37-38mph.
I get about 30 minutes non-stop racing and about an hour bashing.
6 packs usually last me all day (5hrs) at the track. I generally stop
driving when the nitro guys cool their engines.
Next investment may be more True Rc's. They are priced good.
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
George16
Supermaxx
George16's Avatar
01.06.2009, 07:11 PM
Neuenergy 25/50C 5000mah, 2S and 3S wired in series for a 5S total.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
E-fanatic
Brushless only!
E-fanatic's Avatar
01.06.2009, 07:15 PM
Brand: Enerland
C rating: 25
Burst rating: 50
Capacity: 6000
Cell #: 4s
How Many: two 2s in series(I own 4 of them)
Runtime: 18mins(thats really getting on it hard)
Running mmm 2200 combo geared 20/58 with (6.3inch tires) losi super bolt-ons in a traxxas e-revo= about 38mph
Brand: True Rc
C rating: 10c
Burst rating: 15c(I think)
Capacity: 8000mah
Cell #: 4s
Runtime: 22 to 24 mins(that is really getting on it hard)
In same truck as above.
For some reasson the 8000s have more punch and produce 1.8mph faster runs
shaunjohnson
i pwn nitro
01.07.2009, 04:09 AM
thanks for all the help
some good batteries running around here
i want to keep cheap so i came up with a good idea... tell me if this is ok...
i currently own a 8000mah trueRC 10c 3s lipo.
that is being run in the rustler...
what if i just got another one...
that'll give me 6s 8000mah 10c.
they are "rated" for 120A burst but i think he under rates them slightly..anyway...
some snooping around this forum tells me my revo will require bursts/peaks of up to 2400 watts of power.
so on 4s that's 160A's...too much
BUT on 6s that's only 120A's...that's within my burst range
so should/could i run 2 x trueRC 3s 8000mah 10c lipo's???
(yeah that's about one KG of batts there ..is that ok as long as i fiddle with the suspension to carry that weight?)
shaun
sikeston34m
sikeston34m's Avatar
01.07.2009, 08:13 AM
shaun
2 Lipo Packs ran in a series should be the same age. A Brand new one ran with a used one will tend to over discharge the older one.
Double check me on this, but I really don't believe the 3S 8000mah packs will fit the compartments.
About the highest 6S capacity setup I've been able to fit is 5000mah.
shaunjohnson
i pwn nitro
01.07.2009, 09:26 AM
ok understood.
the pack isnt "old" so to speak, only has maby 10 cycles on it.
if i cycle and charge it again and bring it back to health do you think it will be ok?
and i'm doing a rEvo conversion, so there are not any battery compartments to worry about
azjc
01.07.2009, 06:30 PM
2 3s 8000 packs will be pretty heavy, IMO you would be better off with a pair of 3s 5000 packs
