Carbon Fibre Glue
harryf1
Carbon Fibre Glue - 01.18.2009, 12:55 PM
Hi, has anyone ever glued two pieces of carbon fibre together? If so what did you use and how strong was it? Many thanks.
harryf1
01.18.2009, 02:34 PM
Would cyanoacrylate bond well with CF?
George16
Supermaxx
George16's Avatar
01.18.2009, 08:25 PM
Don't use CA. It will harden so much that it will make it brittle and more susceptible to cracking. Use a contact adhesive called UHU-POR which is more superior to all other glues. The nice thing about UHU-POR is that it never fully cures and remains slightly flexible meaning that it will let the carbon flex a bit in case of high stresses.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
jayjay283
jayjay283's Avatar
01.18.2009, 08:55 PM
good tip G.. seems they carry it at Michaels, have 1 down the street, where I get my RIT dye. Just cut up some c/f for the Muggy and wanted to fix the ends http://www.rcgroups.com/forums/showthread.php?t=337447
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.18.2009, 09:56 PM
There are also some 2-part epoxies that remain somewhat flexible when they cure. I can't think of a specific brand. Just sand the surfaces with 80 grit paper and it should be plenty strong.
harryf1
01.19.2009, 12:56 PM
ok, thanks for all your advice. I'll try the UHU-POR and let you know how i get on. Many thanks again.
carbon fiber glue
transtalon
carbon fiber glue - 01.19.2009, 09:08 PM
I personally used a brand Loctite E-120HP Hysol. It is a two part epoxy
and made for bonding carbon fiber. It is very strong but dry very slow.
This stuff is excellent on bonding carbon fiber. I got it from Grainger.
