Revo Hybrid diff Shims
XSKAPE
Revo Hybrid diff Shims - 01.19.2009, 04:31 AM
Hi,
Looking at redoing my Hybrid diffs. Question is what shims will I need? Thanks for your help in advance.
| UE G3 GorillaMaxx MMM 2200kv Combo | G3R CF GorillaRevo MMM Tekno RC Edition Neu 1515/1.5D/F | Losi 8IGHT-B Neu MMM 1512/1.5Y/F |
Serum
Serum's Avatar
01.19.2009, 05:48 AM
Depends on the version you are using, they mostly use 8mm id shimms all around.
I bought a set from Kyosho, with 10 of each, .1, .2 and .3 mm. some .05shimms would be nice too, i don't think they need the .3mm, since they are produced with pretty tight tollerances. (at least the ones I had, which where the 1st gen)
Key to perfect shimming is to make them as tight as possible, without any noticable gear-rubbing..
XSKAPE
01.19.2009, 07:21 PM
Thanks Serum
How can I tell which version it is? I brought the Revo used. All i know is its running HB truggy diffs, and I wish to convert them to the HB buggy.
Serum
Serum's Avatar
01.20.2009, 05:05 AM
Do your diffs use 6 or 8 mm pinion gears?
XSKAPE
01.21.2009, 06:56 PM
I found out the diffs are V2 from the seller. So what shims will I need?
XSKAPE
02.08.2009, 10:33 PM
does any anyone know the part numbers of the shims I need? I've got the V2s
Thanks
madmaxx
REVO madman!
madmaxx's Avatar
02.09.2009, 11:50 AM
Thanks
have you tried calling/E-mailing the manufacturer? just a thought....
REVO picco .26 << too many mod's to list
TT st-1 OS .30 << stock
CEN matrix FRE OS .21rg
http://ca.geocities.com/jleblao/
