2100watts too much for Slash.
coreyfro
2100watts too much for Slash. - 01.20.2009, 08:14 AM
I'm beginning to think that three horse power is a bit much to stick in a Slash. My MMM, my Lehner XXL 1800, and my 6S, 3000mah Lipo survive, per charge, longer than the rest of my ride does.
In otherwords, my v3 hasn't cooked, yet...
...I know Murphy and his *@#$@#$ laws, he'll most likely fry it..........niow...but I'm willing to risk it!
pasan
I <3 RC
pasan's Avatar
01.20.2009, 09:29 AM
Uh yeah... what's the point of running a slash with that much power? They're already uncontrollable on 3S with about 700w of power. You might fry it through utter silliness though, probably the transmission exploding and shorting out the motor and everything else. Get a slayer and use your setup in that instead.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
coreyfro
01.20.2009, 09:42 AM
I bought the XXL 1800, actually, for running with a 2S. I wanted all the torque I could get at the lowest RPM I could get for robotics. The 6S battery was an impulse buy. I need to pawn this thing off before it bankrupts me.
pasan
I <3 RC
pasan's Avatar
01.20.2009, 09:54 AM
There are motors with much lower RPM than that. There are outrunners in the range of hundreds of KV, and pretty small ones at that.
AX10 RTR - Stock :D
t-maxxracer32
t-maxxracer32's Avatar
01.20.2009, 10:20 AM
if you were to get a 500kv motor wouldnt you need more than 6s to run it?
i realize that the lower RPM the more efficient but a slash with a mm 5700 system in it would still kick ass and be alot more controllable.
coreyfro
01.20.2009, 10:31 AM
With my setup, the bot drives at one half a mile per hour per tooth, max with 2S or 8cell NIMH. The 6S was an impulse buy and a mistake
pasan
I <3 RC
pasan's Avatar
01.20.2009, 10:37 AM
I just read up on the XXL 1800... the shaft is 4MM? Where do you find pinions with a 4mm bore?
AX10 RTR - Stock :D
coreyfro
01.20.2009, 11:02 AM
I bored them on a drill press.
Mount the pinion in the chuck and a 5/32nds drill bit in the vice. Works for gears 18teeth steel pinions and up. Anything below that and the pinion will deform when tightening the set screw. 5/32nds is about 3.9mm, but that .1 mm difference is about how much error you'll have from this process.
To key the shaft on the XXL (because it is unkeyed) take a dremel and etch a tiny ding in the case hardened shaft, just enough to mate with the set screw, and no larger. If the color of the shaft changes, you should not cut any deeper and may have already etched too far.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.20.2009, 01:22 PM
You could always seperate the pack into two seperate 3s packs!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.20.2009, 02:05 PM
@ Coreyfro
Just make sure your wheelie bar is in good working order and you'll be fine. I wouldn't be worried about power until you get into the terawatt range....
t-maxxracer32
01.20.2009, 02:29 PM
linc can do the lipo separation.
slimthelineman
slimthelineman's Avatar
01.20.2009, 08:16 PM
kinda off topic but why are most so hesitant to solder on lipos? i have built and repaired several of my own packs as well as others for my buddies. the only thing special i do is cover all tabs i am not currently working on with a piece of 3m 33 vinyl tape to prevent shorting w/the soldering iron.
just curious thats all.
1maxdude
01.21.2009, 06:56 PM
Gear that bastard up and see what she can do!
crazyjr
crazyjr's Avatar
01.22.2009, 02:17 AM
This sounds like my E-gt conversion ,Nice to see another small hi-volt setup. I'm running a basic XL 1200 lehner w/quark 80 and a 5s 2500 flightpower 25c lipo, I haven't seen that power out of it yet though
