making 7 cell packs for emaxx
maximum
maximum's Avatar
making 7 cell packs for emaxx - 12.18.2005, 05:35 PM
I bought a new emaxx ( arriving tommorrow, I'll be on the porch wagging my tail --- wait , I had that removed when I was little) and ordered 4 orion vmaxx super duty 2400 nicads. i know these aren't the best batteries but i'm not going to race this thing just see what i can climb!!!! But i did want to make 2 7 cell packs so i finally found at batterystation.com 2 sanyo 2400 scr's for $3 each. Does anyone know if the vmaxx packs are sanyo's and will these high capacity scr's work well by adding them to the vmaxx packs. I don't know the difference of scx and scr. is it how fast or how much amps they discharge during running.:C:
Nick
COOKIES!
Nick's Avatar
12.18.2005, 05:55 PM
Before you use 14 cells, run the Truck on 12 a few times first.
Putting too many volts (14 cells) in it straight a way won't be pretty.
~ Nick.
coolhandcountry
coolhandcountry's Avatar
12.18.2005, 05:56 PM
The battery pack is only as good as it weakest cell. I don't know about putting them together. They have the same mah so that is a plus.
Peace!
Country
Help support the
Rc-Monster
Buy here
Nick
COOKIES!
Nick's Avatar
12.18.2005, 05:57 PM
As long as they are the same capacity it should be fine.
~ Nick.
maximum
maximum's Avatar
12.18.2005, 06:03 PM
thanks. I know a pack is only as good as the weakest cell, and that should not be the sanyos i'm adding.
maximum
maximum's Avatar
12.18.2005, 06:06 PM
these stock emaxx can run 7 cells no problem without voiding warranty?
coolhandcountry
12.18.2005, 06:20 PM
yes they can. I did it with no problems. Drive shafts take the biggest beating with 14 cells. With a set of cvds it is not worries.
Peace!
Country
Help support the
Rc-Monster
Buy here
Nick
COOKIES!
Nick's Avatar
12.18.2005, 06:32 PM
Honostly, don't run the EVX first run on 14 cells.
I toasted mine, it needs breaking in using a lower cell count. Don't risk it because if you use 14 cells and break it, it voids the warrenty too (yes, 14 cells does void it).
Better be safe than sorry.
~ Nick.
Sylvester
Sylvester's Avatar
12.18.2005, 07:00 PM
As nick stated, just run it on 12 cells first just to be safe, and get used to the truck, than you can convert them to 14 cells.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
