Medusa End Bell Dust Cover
SunnyHouTX
SunnyHouTX's Avatar
Medusa End Bell Dust Cover - 02.01.2009, 02:32 PM
Since I have some time on my hands, I decided to make a dust cover for the rear end bell of the Medusa. I had some Feigao/KD36 end bells lying around so I hacked one up and used the RC-Monster motor clamp to keep things in place. Hope you guys can recycle your old parts this way...
Unsullied_Spy
Unsullied_Spy's Avatar
02.01.2009, 06:03 PM
That's great. I'll have to pull the endbells off my dead Mamba motor and put them on mine. Thanks for the tip!
02.01.2009, 06:16 PM
I took a piece of extra Lexan (from the extra stuff when cutting out bodies), and made a template that covers all the holes and bearing, yet doesn't touch the wires. Then, I use that as a template when cutting out some of that high-temperature aluminum duct tape stuff and just stick that on the end of the motor.
Unsullied_Spy
02.01.2009, 06:43 PM
I've got a washer that I cut to cover the holes on mine, but it's large and doesn't stay in very well under rough bashing.
Rnemhrd
Rnemhrd's Avatar
02.02.2009, 08:44 PM
Sunny I swear today I was trying to figure how to use my xl monster clamp and came up with that same idea. The xl clamp is a little to long for the 36-70 madusa motors. That is funny.
02.02.2009, 09:05 PM
Great tip...on mine 50 series I found some thermal tape good to 300 deg. so far it is still there
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.02.2009, 11:07 PM
The "s" size fits the 50mm medusa motors. The "L" size fits the 60mm motors and if you use a 4mm front cover, the "XL" size fits the 70mm motors.
Having said that, we are changing the heatsinks around at the moment(hence no xl in stock) to offer heatsinks specific to the Medusa motors(as well as others) - including front and rear "covers" built into the clamping heatsinks. :)
02.02.2009, 11:12 PM
Mike, you are the man! When they are done, I will be buying at least one...thanks Mike
SunnyHouTX
SunnyHouTX's Avatar
02.02.2009, 11:19 PM
Mike, that's timely on your part. Can't wait to see what you've got cooking! Thanks.
George16
Supermaxx
George16's Avatar
02.03.2009, 12:49 AM
Good to hear. I need one for my 70mm Medusa. Any estimated date of availability?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
SunnyHouTX
SunnyHouTX's Avatar
02.03.2009, 02:03 AM
Indeed man!
That's a L size motor clamp on my 70mm Medusa. Works fine for me ATM especially like how the heat sink is a little short and that lets the motor wires come through.
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
02.04.2009, 02:02 AM
Just what I was looking for... Sounds great. would also like to know how long... Thank You.
RC-Monster Mike
Site Owner
02.04.2009, 10:14 AM
Can't pin down a definate ETA just yet. I will revert to the old standby "coming soon". :)
Note that it won't be too long, as I am out of the xl heatsinks at the moment, so I am motivated to finish them. :)
02.04.2009, 10:37 AM
But if anyone needs an XL PM me :)
Rnemhrd
Rnemhrd's Avatar
02.04.2009, 08:28 PM
I just rotated the heatsink.worked great.[IMG][/IMG]
