Got this in a trade
halfcab
halfcab's Avatar
Got this in a trade - 02.07.2009, 09:54 PM
the guy I got it from was kind of a hack or the guy he got it from was, he trades a lot, it is set up poorly, I have had it for over a year and only drove it 2-3 times and basically did nothing to it, now I'm on a go fast kick and have a hacker 8xl and mm with a cc bec to run it with so I need some input as to setup and which model g-maxx it is, probably v1, it has a huge amount of bump steer, need cvd's for it, he had a revo knuckle conversion on it and running revo half shafts it rubs the proline shocks
George16
Supermaxx
George16's Avatar
02.07.2009, 10:08 PM
I think that's a G2.
You have a lot of bump steer because the left front turnbuckle is installed incorrectly. It should go between the steering knuckle mounting point like the right front instead of on top of it.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
02.07.2009, 10:24 PM
Damn George, good eye.
halfcab
halfcab's Avatar
02.07.2009, 11:11 PM
yeah, i just changed that before I took the picture, I was not pleased with it and unimpressed by it's performance and I was lazy so I shelved it, just pulled it down today and started looking it over , with dual 4s packs and the 8xl hacker it should be fun, question, should I lock it in second or keep it a 2spd
azjc
02.07.2009, 11:21 PM
IMO the 1st gear would be worthless with all the torque a BL motor produces
Maxx42
Maxx42's Avatar
02.07.2009, 11:26 PM
It looks like you are missing the stiffener posts in the chassis that connect the rear skidplate to the upper chassis plate. You can probably just use a pair of emaxx steering posts instead. They will give that rear extended section more support.
G-Maxx MMM/1515 2D
T4 Factory Team MM/Lehner 3600XL
RC18t 5400 Mamba
MGT 8.0 conversion MMM/1521 1.5D
02.08.2009, 03:46 AM
That truck looks to have a tamiya front driveshaft... Looks like a high lift piece to me, but might be off a jugg considering the age.
As far as the 2 speed goes, get a gmaxx single speed for it.
Man, I am drunk.
Rivermaxx
02.08.2009, 10:49 AM
If you have to much power dont expect the diffs to hold up or the tranny and center drivshafts for that matter. The outer shafts are the next weak link but will hold for a while. what the difference between a G2 chassis and a G3? I thought a G3 was extended which this one is but I am still not sure.
Maxx42
Maxx42's Avatar
02.08.2009, 12:23 PM
The chassis plates were slightly thicker in the G3 chassis. I have the G2 with the G3 rear extension. I think the G3 plates are about 1/16 of an inch thicker.
G-Maxx MMM/1515 2D
RC18t 5400 Mamba
Gee
A Horse's Ass
Gee's Avatar
02.08.2009, 05:18 PM
http://monster.traxxas.com/showthrea...saver+mod+3906
Check out the mod above for the sloppy steering. Don't know it you can get it too work with your chassis. I've done it on the stock chassis and a FLM chassis. Helps a lot.
02.11.2009, 08:51 PM
That thing needs a good clean, and a few other areas need some attention too:
Lock the tranny into 2nd gear, and install an RCM steel idler.
Change the front drive shaft to a 3.3spec item too, may need cutting to length.
Rear stiffener posts can be got from GorillaMaxx directly, just look in the spares section for the G3 chassis (will fit fine, as the thicker upper plate is thicker in the upwards direction).
Swap the plastic steering posts (they look plastic anyway) for the optional alloy ones, and then get yourself a nice Kimbrough large gas truck servo saver for whatever servo you fit.
Get a servo with atleast 200oz/in of torque ideally.
Should make for a nice project truck with all that in mind.
halfcab
halfcab's Avatar
02.11.2009, 09:40 PM
problem is not enough $$ to go around, trying to finish up the buggy conversion...., this one is on the back burner, should not take too long the buggy is getting close, that and I'm not sure how crazy I want to get with it
mmm v1/cc bec
neu 1515 1y f
ofna hyper7
several crawlers scalers and comp rigs
cc 4600 mm sys in a slash and a stock slash
soon to be reserected gorilla maxx v2
02.11.2009, 09:58 PM
You could always trade it again...
halfcab
halfcab's Avatar
02.11.2009, 10:30 PM
what are you offering?
I need big lipo's for my buggy, 4s-5s 5k mah plus
just kidding, I kinda want to see it run good, mabey a little beach running might be kinda fun, the beach is only 25 minutes away
mmm v1/cc bec
neu 1515 1y f
ofna hyper7
02.11.2009, 11:18 PM
Like a 4s5k enerland pack or a 5s 4k pack?
