wiring of brushless
makana59
makana59's Avatar
Exclamation wiring of brushless - 12.24.2005, 12:07 AM
Hello GUy,
Newbie to the world of brushless... first just purchased the feigao 9L and warrior 9920. When wiring the motor to the speed contorller... does it matter what wire goes to which wire.. theres the red, green and yellow but all the wires on the 9920 are all blue. Does each one just go to each wire or is there a special one for each? Is there a diagram on line with the wiring diagram. For the full wiring i also purchased the BEC does anyone have the diagram for the full wiring. Thanks guys, Grant
rchippie
rchippie's Avatar
12.24.2005, 12:12 AM
It does'nt really matter. Just make sure the middle motor wire from the speedo goes to the middle wire of the motor. If you hook it up and the vechile goes backward simply switch to two outer wires. If you look at the battery wires from the speedo they are marked positive (red) & negitive (black). So the two outer motor wires from the speedo are the same, what i do to mine is put a small piece of red & black heat shrink on the motor wires from the speedo to identify them as such.
REAL MEN RUN BRUSHLESS
makana59
makana59's Avatar
12.24.2005, 12:24 AM
how do I know which is the positive and negative on the motor... they have a red, grenn and yellow.. the green is in the middle so i know from what you said that goes to the middle on the speed controller but as for the + - on the motor..?? Thanks for the help.
rchippie
rchippie's Avatar
12.24.2005, 01:03 AM
With a BL motor it will work no matter what way you have the positive & negitve wires hooked up as long as the middle wire from speedo is connected to the middle wire of motor, thats the most important issue. Like i said eairler if you hook it up and it runs backwards simiply switch the two outer wires.
Serum
Serum's Avatar
12.24.2005, 04:51 AM
You don't need to switch the two outer wires.
You can change any two wires on the motor. with BL there is no + and -. this changes with a motorturn. and with three wires, their is always a star between the 3 wires, no matter how you wire them.
