Slight cogging issue w/mm esc and Tekno/Neu 1509 3300kv on 3s
Slight cogging issue w/mm esc and Tekno/Neu 1509 3300kv on 3s - 02.11.2009, 10:10 PM
I have a slight issue w/ cogging. At full throttle look out! WOW is that truck fast..however, at almost a stand still, hop on throttle and it stutters a bit for 2 sec. then it is fine.
My esc settings: 1509 2DF 3300kv w/mm esc on 3s
1. low start power
2. 10% punch control
3. 60% brakes w/reverse delay
3. lvc to 3.2 v/cell
4. timing to 2
I don't remember the pinion size..16T I think?
Could I need to braid motor wires a bit...it seems to happen more often when it is farther away than when it is close.
