pinion gear ???
RUSTED
pinion gear ??? - 02.13.2009, 09:13 PM
hey ,
does anyone make a pinion to mesh with this type of gear?? as u can see from the pic it's mod1 but the teeth are not straight
ID:	6389   Click image for larger version
ID:	6390   Click image for larger version
02.14.2009, 01:06 PM
Helical spur gear, you wont find a pinion to fit that unless you get a custom made one from https://sdp-si.com/eStore/ , and I dont see anything quite suitable there either actually. Your best bet would be to ditch that spur and find a normal one to replace it...
azjc
02.14.2009, 01:47 PM
here is a link to some helical pinions that some of the heliguys use. The advantage to using them is the are more quiet, performance suffers a little
http://www.readyheli.com/Align_Pinions_s/111.htm
02.14.2009, 04:13 PM
Those are quite nice looking, but they're all Mod 0.4 or 0.6, no 1.0 that I can see saddly. Worth further investigation though possibly...
RUSTED
02.14.2009, 05:40 PM
thanks for the help but i replaced it with a centre diff from a x1 crt 51 tooth , i have a medusa 70mm 2300kv should i gear it for 41 mph or 45 mph ???
its an emaxx btw
02.14.2009, 05:50 PM
On 4s lipo? 41mph would be good, but experimentation is the key to good temps and performance- try different pinion combos until you fin the one that works best for you (cool motor/esc/lipo temps + enough speed for what you are wanting to do).
