CEN R2 Matrix....!!
jzemaxx
CEN R2 Matrix....!! - 03.01.2009, 07:14 PM
Guys I'm about to move up to the 1/8th scale buggy class racing. Going with the new R2...how does this setup look??? Am I missing something?? Going with a 1512 1Y and MMM ESC on twin 2S's in parallel.
Differential Ratio: 2.888888888888889
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 20
Total Voltage: 7.4
Motor KV: 2750
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0035
Spur/Pinion Ratio: 2.3 : 1
Total Ratio: 6.64444 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Total Motor Speed: 20350 RPM
Vehicle Speed: 39.18 mph (62.94 km/h)
Effective KV Value: 2750
KT constant: 0.49 oz-in/A
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Hardstyle
Hardstyle's Avatar
03.01.2009, 07:24 PM
I don't know much about buggys, but isn't everyone using something like 4-5s lipos on them? 2s lipos with 2750kv might have a less torque? Personally I would put some lighter kv motor, more voltage and gear it down.. But again I don't have a buggy :D
jzemaxx
03.01.2009, 07:31 PM
Its to keep the weight down. Also I'm only trying to go 40mph....not 60 like most. Also buggies are VERY light so running higher KV motors and lower voltage is not as bad.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
jhautz
jhautz's Avatar
03.01.2009, 10:09 PM
Ummmm.... I agree with the last guy. Your not gonna have much success with 2s in a 1/8 buggy.
I would strongly recoment going with at least 4s.
to make it...
or break it...
Silent...But Deadly
jzemaxx
03.01.2009, 10:43 PM
I figured since it was so much lighter, it shouldn't need such a large motor and lots of voltage. Heck 3S on a 1512 1y on my buggies truggy is stupid fast and runs 35-40mph and runs cool. The buggy is another 1-2lbs lighter.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
rootar
rootar's Avatar
03.01.2009, 11:06 PM
go with a 1512 2.5d on 4s or 5s and gear for 40 and youll be golden...
or atleast go 4s on that 1512 1y and gear down for 40...... your gonna have a HOT motor and puffed lipos if you try to put a little 1512 only spinning 20,000 rpm in a 7.5-8 pound buggy and gear it for 40mph.... it just dont work like that.....
jzemaxx
03.01.2009, 11:09 PM
I was also looking at the 1515 1.5D
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
brushlessboy16
brushlessboy16's Avatar
03.01.2009, 11:11 PM
the 1515 1y on 4s seems to be a hot ticket.
jzemaxx
03.02.2009, 12:01 AM
Just trying to save weight. Using a 1512 should be a little lighter.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
03.02.2009, 12:32 AM
A 1512 will be fine. I would go with 5-6s and smaller packs. I run a 1600kv medusa 60mm (similar to a 1512) in a hyper8 with 6s 2170 mah 25c fp lipos. It is well under 8lbs with batts and the body. Runs great too!
jzemaxx
03.02.2009, 02:10 PM
What kind of run time??? Our A-mains are 30 mins......will it make that kind of main??
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
03.02.2009, 02:47 PM
No - 30min mains are going to need a battery change...
jzemaxx
03.02.2009, 02:48 PM
I wonder if I could get away with a 3S setup and run 2 in parallel.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
03.02.2009, 02:58 PM
You will have a faster more reliable setup without - too heavy a battery will just slow you down and cause breakages...
I think you'd be better off with a change - JHautz runs in longer races - I'd listen a lot to him...
jhautz
jhautz's Avatar
03.03.2009, 01:34 AM
2 3s packs in parallel have the same amount of energy as 2 3s packs in series or one 6s pack of double the capacity. Its all going to weigh the same. so what are you gaining by running the lower voltage. You will get better runtimes and lower temps by going with double the voltage and half the capacity as long as you choose an appropriate motor to go with the higher voltage.
Ive been racing my 1/8 buggy and have tried alto of different motors and voltages. 3s,4s 5s 6s etc... and easily a couple dozen different motors. So far the best combo for staying cool and giving long run times on the track without being totally overkill and undrivably powerful has been a 5s setup on either a 1512/3d or 1512/1.5y. Both have been great motors for 5s racing.
I thought you said you were looking to save weight??? Saving weight and trying to run for 30 minutes without a pack swap are totally contradictory to each other. to make 30 minutes you would probably need 6s and 6000mah minimum 5s 8000 or 4s 10,000mah. Thats a heavy pack. you will be better off going with a smaller pack and doing a swap if you want the buggy to handle properly.
Just remember, the lower the voltage you choose the higher capacity pack you will need to carry the same amount of energy.
If 30 minute mains are your goal I'd recommend the 1512/3d and a pair of 5s 4000mah packs and swap them at the 15 minute mark. If you want to be safe on making the runtime go with a pair of 5s 4300mah packs. Neuenergy has a deal going on some nice 5s 4300mah packs right now.
to make it...
or break it...
Silent...But Deadly
