RC Timer 50A brushless/brushed ESC
mjderstine
mjderstine's Avatar
RC Timer 50A brushless/brushed ESC - 03.04.2009, 10:14 AM
hey guys, i found these on ebay, and the one thing that makes them stand out to me is that they run brushed and brushless. they are also cheap which could make them appealing as a nice esc for 1/10 bashing. 4 cell lipo is also a very cool thing to have.
here are some specs direct from ebay.
i would love to get some thoughts about this thing from some of the more educated guys on ESC's from here. i swear, most of you have masters degrees in electrical engineering to do what some of you do.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=120354459145
High quality
1.1 Output: Continuous current 40A, working current at 50A can last over 1 minute,burst current 60A.
1.2 Input: 4-12 cells NiMh/NiCd or 2-4 cells LiPo. (Note)
1.3 BEC Output: 6V/1A.
1.4 Resistance: 0.0006 Ohm.
1.5 Motor Supported: Sensored brushless / Sensorless Brushless / Brushed
1.6 Suitable Brushless Motor: 5.5T and >5.5T
1.7 Suitable Car: 1/10, 1/12 on-road or off-road cars / trucks for normal race.(Great power for 2S lipo battery)
1.8 Size: 31.5mm(L) * 27.5mm(W) * 24mm(H).
1.9 Weight: 30g(Without wires)
Note1:
For brushless motor, the ESC supports up to 12 cell NiMh/NiCd (or 4 cell Lipo) input; While for brushed motor, the ESC only supports up to 6 cell NiMh/NiCd (or 2 cell Lipo) input.
For 4-6 Cell Ni-xx: You needn't change the fan coming with the ESC;
For 7-9 Cell Ni-xx: You must change the fan because it cannot work with such a high voltage, so please choose a high voltage fan or supply the fan from the receiver (+6V);
ID:	6503   Click image for larger version
mjderstine
mjderstine's Avatar
03.05.2009, 10:46 AM
anyone at least have an opinion? or have i missed a post about this that came earlier?
03.05.2009, 11:06 AM
Specs look ok, if a bit low. If specs aren't inflated, it might be ok running 4s on a low kv motor in a light 2WD 1/10 scale (max) vehicle; anything larger, or lower voltage, will probably exceed the low 40A spec. And it looks like it doesn't have a switching BEC, so if running anything over 2s, you'll need an external one or a receiver pack.
It's really hard to say though. There is more to an ESC other than specs: customer service/warrant, upgradability, smoothness, etc
mjderstine
mjderstine's Avatar
03.05.2009, 11:14 AM
i was thinking it would be used for nothing more than 1/0th touring car, maybe a 1/0th 4wd buggy, but leave it at that. it no MM by any means, and probably equivalent to the 35A hobbywing esc
03.05.2009, 11:16 AM
1/0 scale? Isn't that infinite?
Anyway, as long as you understand the limits, it should work ok if it can live up to the specs.
mjderstine
mjderstine's Avatar
03.05.2009, 12:46 PM
its either infinite or not a real number!
i think i will stick with my MM, and get some ezrun esc's for bashing.
03.05.2009, 12:49 PM
Nope, anything divided by 0 is gonna be infinite. A non-real number would be a vector, like when you try to take the square root of a negative number - basically anything other than the X axis.
mjderstine
mjderstine's Avatar
03.05.2009, 01:21 PM
yup, i actually do know what you are talking about. guess my joke didn't work. an infinite anything is almost undefinable and hard to think about, and so could be said by the layman that its not a really number, since there isn't a number to represent infinity. because 10000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000
is still not infinite, you can always add one :)
sorry i will quite my rambling!
03.05.2009, 01:30 PM
lol, I guess I read "not a real number" as "imaginary". And infinity IS a number; it's a tired 8.
vbxt
03.05.2009, 01:45 PM
The specs are very similar to the EZRUN 60A Esc (especially when they talk about the fan). I think that this is just an EZRUN.
mjderstine
mjderstine's Avatar
03.05.2009, 03:53 PM
my thoughts too vbxt.
not to throw this in another direction, anyone seen the viverrine 100A esc on ebay as well? rebadged ezrun? or not?
Manual
rctimer
Manual - 10.20.2009, 10:59 AM
High quality
Note1:
Thanks for your message.
Please use this link:
http://www.rctimer.com/download.htm
Nina
