Hpi hellfire ss
obelix
Hpi hellfire ss - 03.08.2009, 03:04 AM
I am finally ready to order the Motor, esc for the hellfire build but I need some advise.
This is the setup I was looking at getting
Mamba Monster v3 Running 6s trackpowers 25c
NEU 1515 2.5d
std gear ratio 13t mod 1 pinion 53 spur
I do not know all the gear ratios to enter in Brian G's speed calculator so I based this on the rpm I would get from a 28 nitro engine (35000) and increased it slightly I also selected this motor because RC Monster has It in stock.
Is this a good setup or can I get better ?
Does anyone know if there are aluminium diff cases available for the hellfire if not which other make would fit.
Thanks
HPI BAJA 5B SS
HPI HELLFIRE SS
KYOSHA INFERNO SP VXL
RUSTLER VXL
BANDIT VXL
