MMM PC Connection issues
Chris Corbett
MMM PC Connection issues - 03.08.2009, 07:09 AM
I am trying to connect my MMM V3 to pc for first time programming. Have installed supplied software and when I plug in speedo the USB light is green but is not detecting esc.
Under choices of esc to connect the MMM is not listed???
Also I assume the esc needs power AND be switched on to program.
Any advice greatly appreciated as I am getting more and more frustrated!!
03.08.2009, 08:53 AM
NO power needed to the esc the brains board is powered by the esc. IIRC the switch should be on.
What OS are you using?
MMM PC link issues
Chris Corbett
MMM PC link issues - 03.08.2009, 10:59 AM
Thanks for reply. OK, I'll try with power disconnected.
Running Windows XP by the way
03.08.2009, 12:12 PM
Make sure you have .net
mmm pc issues
Chris Corbett
mmm pc issues - 03.08.2009, 02:31 PM
not sure what you mean by .net? Do you mean make sure internet is connected? If so then it has been.
I am sure I have wrong software as i can't understand why MMM isn't listed???
