Flux&savage x
onetoo3
Flux&savage x - 03.18.2009, 10:50 PM
The center gear box in the flux is the same as the X
JThiessen
JThiessen's Avatar
03.18.2009, 11:25 PM
ok.............?
03.18.2009, 11:49 PM
No , the casing is the same. The input shaft is the same as is the output shaft. But the transfer shaft is different.
scarletboa
scarletboa's Avatar
03.19.2009, 12:40 AM
i'm thinking about using a flux tranny in my conversion. it all depends on whether i use a plane esc or a car esc. (braking options)
the flux tranny can't use mechanical brakes as far as i know.
doo540
03.19.2009, 05:33 AM
I would disagree with that. It has all the mounting points for the mech brakes.
I had my 3speed right beside my Flux and they look teh same on the outside.
After I recieved my "new pulled from kit" flux tranny off ebay, I had to shim all the chafts and all the gears. The big gear on the idler shaft was really loose and wobbling around.
Joram
Nitro?? BL rulezzz
03.19.2009, 02:44 PM
I'm going to use the Flux tranny with mechanical brakes, just set the brakes on your controller OFF!
Greetz,
Joram
Standard is not an option!
  Send a message via MSN to Joram
onetoo3
03.19.2009, 03:29 PM
yes the idler gear 44t/shaft set #100905 and washer 6x15x0.2mm #86972 is different but the rest looks like whats in a savage 21. so i want to get the savage x gear box #85052 and the flux idler gear&shaft + the gears from my 21 and that will give me a flux tranny. i hope....
Joram
Nitro?? BL rulezzz
03.19.2009, 04:39 PM
You also need an extra pin and E-clip!
Then you have the parts to convert
Greetz,
Joram
onetoo3
03.19.2009, 07:40 PM
how could i forget the
extra pin and e-clip
Thanks Joram
Joram
Nitro?? BL rulezzz
03.20.2009, 04:49 PM
I have recieved today my Flux shaft & gear set!!
The clips and pins are included, so you don't need to buy the apart, i did that cuase i didn't knew the come with the set.
Greetz,
Joram
