removing fliud from a diff
azjc
removing fliud from a diff - 03.22.2009, 07:36 PM
I am new to truggies so I havnt done this yet...what is the fav method of removing fliud from a diff? I was thinking maybe a Q tip.....I have 10k weight in the centerdiff I was thinking about trying 20k
03.22.2009, 07:50 PM
I spray my diffs out w/brakeclean
03.22.2009, 08:13 PM
Or tip half out and refill with 30k.
I also use brake cleaner after I remove the internals and wipe it out with a rag. If i want the internals clean I put them is a small mesh kitchen sieve (collendar, sp?) and spray the brake cleaner thru that too. Carb cleaner works too, or nitro clean. Whatever aerosol I can find that is cheap. I am sure that simple green and water would work well, but will require drying after you wash the internals.
03.22.2009, 08:18 PM
I also cheat and just dump out and refill if I feel that I need thicker/thinner fluid and it hasn't been that long between changes.
If I do spray w/brakeclean, I do let all the gears dry before I reinstall.
George16
Supermaxx
George16's Avatar
03.22.2009, 11:11 PM
Naptha works best for me. I put the diffs in a mesh screen in a container of naptha and they'll come out clean. The naptha dissolves the diff oil without leaving any residue.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
03.23.2009, 08:21 AM
Ah! And to think I've had a gallon container of Coleman fuel laying about and never thought to use that. Thanks for the tip! I've got a 8 spider diff that needs a flush.
brushlessboy16
brushlessboy16's Avatar
03.23.2009, 09:27 AM
where do you get naptha?
sleebus.jones
03.23.2009, 01:32 PM
Read ze above post:
Coleman lantern fuel = naptha
Finnster
KillaHurtz
Finnster's Avatar
03.23.2009, 04:19 PM
Jesus, that sounds harsh.. I just pour it out and wipe w/ paper towels to get most of it off. Can't say I'm particularly anal about it, and if a tiny bit is left I don't care. I get enough chemical exposure at work so I try to avoid it everywhere else. Whatever works.
Jube
03.23.2009, 08:55 PM
In the paint Isle at Lowes or Menards hardware stores.
Shark413
Shark413's Avatar
03.23.2009, 10:24 PM
Air compressor and some rags.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
