Motor keeps loosening up on motor mount.... -
03.22.2009, 08:42 PM
Having an issue w/the motor moving on motor mount. The screws are as tight as I can get them and the motor still slides away from spur. The screws are the correct length. This happened to me today several times...I would re-tighten and then 10mins. later it would back off again..by the 4th time happening, I had to walk away for a minute or else there would have been a crt.5 in pieces.
Are you guys using any lock washers of any kind.
