They wont fit in the maxx arms, you can make them fit but it requires a bit of modification and will weaken the arms, some searching and you might be able to find a post where someone took some Al arms and modified them to use LST shocks.
I'll see if I can make a size listing and add it to the link posted earlier
OFNA Ofna LX One shocks
Front Shocks Measure 103mm C to C extended 4"
Rear Shocks Measure 123mm C to C extended 4.8"
Seems these would be just right
How do you guys like the THe LOSI 8eight fronts ? they are much shorter
