Getting e-maxx to track stright?
Chris911
Getting e-maxx to track stright? - 01.08.2006, 08:22 PM
I have a time getting my e-maxx to track stright is a after market Chassis etc easier to allain?
Sylvester
Sylvester's Avatar
01.08.2006, 08:26 PM
Are you talking about how the wheels are alligned? OR when your driving it drives away to another side, if so, i dont think it makes a difference, but if you get g-maxx chassis, the better COG might help it allign itself.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
squeeforever
squeeforever's Avatar
01.08.2006, 09:01 PM
the chassis isnt the problem. its your camber and toe in. set the camber at about 1 to 1 1/2 degrees in the front and 0 to 1/2 in the rear with a VERY slight toe in if you dont race but a VERY VERY slight toe out if you do race.
coolhandcountry
coolhandcountry's Avatar
01.08.2006, 09:35 PM
Do you have problems when on the gas or coasting? If you have more weight to one side or you shocks and springs are differnt it will track funny.
Peace!
Country
Help support the
Rc-Monster
Buy here
Chris911
01.08.2006, 09:45 PM
If i set the camber right the steering don't work right. For example when i turn right and go straight again the wheels wont come back stright because that hex screw that adjust the camber is to tight and if i have it loose the steering is fine but then the truck wont track right and the wheels will wobble. I have luped all the steering parts and it seems to make no differance.
And for toe in both tire rods are the same length, i don't know any other way to check it.
coolhandcountry
01.08.2006, 10:58 PM
sounds like a dirty pivot balls. Check the shocks to. Make sure springs have about the same preload on them. If a wheel has more traction it is going to track funny. The back end is just as importans as the front. The servo saver makes a difference to. The kind of servo helps.
Peace!
Country
Help support the
Rc-Monster
Buy here
Chris911
01.08.2006, 11:19 PM
I think it has did this since i bought it new but has gotten worse over time. I'm ready to take it to a hobby shop and let them firgure it out or buy a new one.
That's how tired i am of trying to figure out what's wrong with it.
btw does the G3 Race Suspension keep the same ride hight?
coolhandcountry
01.09.2006, 09:28 AM
You can adjust the g3 for same or lower ride hieght. It has more adjustment than the stock. Make sure you turns buckles don't have to much plat to. Are you running the stock servo saver and stuff. The ue servo saver is much better. Make you think you have another truck.
Peace!
Country
Help support the
Rc-Monster
Buy here
Chris911
01.09.2006, 12:34 PM
What's a good set of Axle carriers/ steering blocks and Pivot balls to use with the G3 Race Suspension?
Serum
Serum's Avatar
01.09.2006, 01:08 PM
Mike has got this Integy's, those come with bigger bearings as well. pivot balls; the best available money can buy are the UE steel ones.
Chris911
01.11.2006, 01:04 PM
this says to use plastic pivot ball caps where do i find thouse?
squeeforever
01.11.2006, 07:07 PM
the stock are plastic
coolhandcountry
01.11.2006, 09:13 PM
The stock emaxx ones are plastic squee. You can get the alumium with o rings on them. Mike has these. I used the stock ones with loc tite. have had not problems yet.
Peace!
Country
Help support the
Rc-Monster
Buy here
squeeforever
01.11.2006, 09:21 PM
oops...:o :o i was thinking revo. i remember there aluminum now that you mention it. i think that the aluminum ones with the o-rings would be fine. i run plastic ones on my revo with aluminum knuckles and they stay fine.
coolhandcountry
01.11.2006, 09:37 PM
It is okay squee. Is the revo and the maxx the same size. Maybe they interchangible or something.
Peace!
Country
Help support the
Rc-Monster
Buy here
