mmmv3 reciever wire can be cut short?
darkdemon
mmmv3 reciever wire can be cut short? - 04.03.2009, 10:14 PM
hi want to cut reciever wir it got caught in the spur geat a little bit and squashed it a little wire showing can i cut and add new reciever wire to it?
04.03.2009, 10:24 PM
Yes, you can do that with no problems. Don't know how that will affect the warranty though...
You can either cut the bad section out and resolder/heatshrink the ends together; or for a cleaner look, get a servo connector kit and put new pins/connector at the end of the good section.
brushlessboy16
brushlessboy16's Avatar
04.03.2009, 11:11 PM
I have done it and it does not effect the warranty. the only soldering that does void it- is soldering directly to the board.
darkdemon
04.04.2009, 06:26 AM
thanks for that guys
04.04.2009, 07:26 PM
To protect mine, I removed the rx plug, put some narrow heatshrink tube over the rx lead, then put the plug back on- looks nicer and protects the rx lead to boot.
04.04.2009, 07:28 PM
FWIW I had the same issue with a servo lead, rewired it and work fine after...
brushlessboy16
04.04.2009, 07:31 PM
cut the wires like this
yrb
-yellow orange and browns so if the heatshrink wears through you do not short your BEC
