Go Back   RC-Monster Forums > Support Forums > Team Tekin
motor and cc esc
super dave
super dave's Avatar
motor and cc esc - 04.05.2009, 12:10 PM
can you use the new 1/8 motors with a cc esc does any one know or should you just get the the combo. i ask because i have a couple cc esc still. thanks
04.05.2009, 12:34 PM
Which CC ESC are you talking about?
super dave
super dave's Avatar
04.05.2009, 01:10 PM
hey brian i have mamba v3
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.05.2009, 01:25 PM
So you have a mamba monster v3? What motors are you talking about?
04.05.2009, 01:28 PM
Since he said "the combos", I assume either the 2650 or 2200.
You can use the MMM ESC with pretty much any motor you want as long as the rpm's aren't too high and is sized for the vehicle.
super dave
super dave's Avatar
04.05.2009, 01:43 PM
yah i was thinking of using the 2000 motor in my truggy with the v3 on 6s pacs
TekinTeamMgr
TekinTeamMgr's Avatar
04.07.2009, 09:07 PM
You can use our T8 motors with the CC esc, it's not sensored but it will work. The full potential will not be realizes without the RX8.
  Send a message via Yahoo to TekinTeamMgr
Unsullied_Spy
Unsullied_Spy's Avatar
05.02.2009, 07:07 AM
Can we get plugs for the sensor port so they don't get dirty if run as sensorless? I'm looking for a motor and ESC for one of my Hyper 7s and I'd like to run the MMM with the 1700KV T8.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.02.2009, 09:12 AM
I would like a slightly shorter sensor wire as well. :)
super dave
super dave's Avatar
05.02.2009, 09:32 AM
the update is on the factory web site now for the hotwire to use with rx8 (thanks ty and jim)
TekinTeamMgr
05.02.2009, 11:37 AM
We have a 100mm sensor wire also that is half the length: TT3811
A piece of servo tape or electrical tape should do the trick. I'll look into the plugs.
Unsullied_Spy
05.02.2009, 07:48 PM
Tape works fine, I was wondering if there was a little rubber or plastic plug we could put in there for a more permanent solution though.
js058515
Thank You Brushless Gods!
js058515's Avatar
05.03.2009, 12:59 AM
+1 on sensor plug........and a vote for a longer sensor wire.
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.03.2009, 01:53 AM
A longer sensor wire!?!?!...you've probably mounted you motor to the front huh?bc the included wire is pretty long already LOL
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
TekinTeamMgr
05.03.2009, 01:24 PM
If there is a need or desire we will look into it. I'm sure there is as guys adding these to M/T or some other app may want one as well. I was thinking 250mm but you're wanting longer than that so maybe 275 or 300mm.
