Originally Posted by The Dane
hey Thomas,
I am having trouble calibrating my Savage flux I can get through the normal setup procedurer but then when the esc shows the yellow lead constant I barely have to touch to the throttle and it goes wild and does not go back to neutral . It wil start out in reverse and go back and forth between green and red. If i apply the brakes it will goto neutral yellow for at few seconds but it will glitch and the burst into full forwards.
Seems as if the esc and the receiver/controller don't communicate properly. I have also had some glitching issues from the standard receiver/ controller from HPI. I am running flightpower lipo cells 2 x 7.4 volt 5350 Mah.
I hope it is only the receiver or controller which the problem??
Try resetting it up from scratch. Also try updating your esc.
