How do you keep revo trannys in one peice?
traxxasrevony
How do you keep revo trannys in one peice? - 04.09.2009, 07:58 PM
blew apart my brandy new 3.3 tranny today. doing a speed run it shifted to second fine was gaining speed then baazinnggg and she slowed down.
how do you keep you revo trannys from stripping gears? as im lost.
by the way this is with a mmm on 4s with a fegiao 8xl. not a very high powered setup.
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.09.2009, 08:03 PM
You can try robinson racing steel internals.
traxxasrevony
04.09.2009, 08:36 PM
i was thinking that but for 122 for the whole set i think ill pass on that.
brushlessboy16
brushlessboy16's Avatar
04.09.2009, 08:39 PM
ditch the trans an mod a 8th scale center diff to fit.
04.09.2009, 08:44 PM
Lock it in 2nd, that will keep the tranny together when it does not shift...
traxxasrevony
04.09.2009, 08:55 PM
actually tell you the truth i just took a closer look at it, i was pretty pissed when i tore it apart. its the 1st speed that blew. everything else is fine. just the 1st speed part of the input gear. didnt strip the big 1st speed gear tho.
squeeforever
squeeforever's Avatar
04.09.2009, 09:14 PM
Could be heat related causing the plastic to become weak. Try a little grease in it.
George16
Supermaxx
George16's Avatar
04.09.2009, 09:25 PM
I have RRP gears and have locked the tranny on my revo conversion. No problems with the Neu on 5S.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
killajb
killajb's Avatar
04.10.2009, 07:50 PM
I had the same problem with my revo and purchased the $100+ Robinson Racing gears, but in hindsight it wasn`t completely necessary. I think you can remve the first gear altogether and lock the shifting mechanism so that it always stays in second gear. I beleive Brian G posted a thread about it soemwhere.
Hey Lito, I`ve been here in Tokyo since the 1st and found tons of RC stuff everywhere, including the Futaba factory in Chiba. Ever make it up this way much?
04.10.2009, 08:03 PM
Originally Posted by killajb View Post
...I beleive Brian G posted a thread about it soemwhere...
Yeah, there's a sticky in the Revo subforum. Also talks about modding the pins too. Once I made the mods, the tranny never had another problem.
George16
Supermaxx
George16's Avatar
04.10.2009, 08:20 PM
You need to come down here in Yokosuka. I can give you a tour of the base the the ship(an aircraft carrier so it's huge). I can only do it on the weekends though.
Most of the action is in Chiba which is about 3 hours north of Yokosuka. I had been to the Futaba factory once since driving is a chore. Lots of traffic and toll fees . They also have there own tracks which is nice, by the way. Most Japanese offroad tracks are designed for the buggies such as the Mugen MBX6, Kyosho MP9, HPI, Hot bodies. You can also go to Akihabara(electronics town). There are 4 huge stores down there. One of them is 8 stories high and merchandise ranges from plastic models to hobby grade stuff(water, air, and land).
Pm or call me if you're interested in coming down here. I'll pm you my phone number.
Here's a link to the map for the RC shops in Akihabara:
http://liaison.ms.u-tokyo.ac.jp/agusta/akihabara.html
Revo with OS .18TZ
