(Possible) New Controller
Mister_Anderson
Mister_Anderson's Avatar
Question (Possible) New Controller - 01.13.2006, 04:31 PM
I have a question. On my Feigao 6s it says it draws 108 Amps. Is that constant or at full throttle? Would it be neccessary to run a controller of handling the full 108 amps continous or at a burst?
Any Comments aprreciated.
I have now decided to get a WATER-PROOF Speed Controller, I was looking at the Barricuda-125 or the Barricuda-80. I know these are boat controllers but would they work? If not does anyone know of a water-proof car/truck controller.
Also, Any suggestions comments welcome thank you.
A.K.A. Rusty Boy
E-Rusty:
Mamba Max ESC
5700kv Motor
RCM-RC Chassis
A123 Racing 2300 MaH 2s1p Series
16/84
Top Speed M.P.H. ~45.
"Profit Is Not a Four Letter Word, But Rape Is Illegal."
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
01.13.2006, 04:37 PM
The MGM Compro RC Car controllers come with a waterproof option, so you go for that. I wouldn't submerge it in water, but it'll do. That is probably 108 amps burst, so a MGM 80 should probably cover it, correct me if I am wrong guys. Personally I like to have some insurance, so I'd probably run a 120 amp controller:M:
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
01.13.2006, 05:27 PM
My Mtroniks Pro controller handled it fine, that was reted to 80 amps constant or thereabouts. Its fully sealed & waterproof as well as being very cheap ($160) for a car controller.
I also have a Mtroniks Truck which runs completely cool with my 6s, but it does have a massive heatsink on the bottom so it should do!! (also waterproof, only $185).
Personally I would recommend against a boat/plane controller, or the MGM's if you want waterproof, as they're pretty exposed.
  Send a message via Yahoo to Rtsbasic
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.13.2006, 08:39 PM
Your batteries would probably burn out before they could put out 80 amps continuous.
Area 52 Ranch Raceway
T.R.C.R.
MetalMan
MetalMan's Avatar
01.13.2006, 11:40 PM
The amp rating on a motor doesn't really mean anything. It doesn't stand for continuous or burst, but is just a number that is assaigned to the motor.
IB3800s can easily provide 70amps continuous, as I have seen in an ongoing life cycle test in which a cell is charged at 6amps and continuously discharged at 70amps. So far it is at 16 cycles.
Serum
Serum's Avatar
01.14.2006, 05:25 AM
A 9920 would cover it too.
Metalman;
I've heard those IB3800's are able to deliver 250A peaks! (i don't want to know their voltage though) I was told by maxamps.
