If your Neu doesn't have gromets?
Snipin_Willy
Snipin_Willy's Avatar
If your Neu doesn't have gromets? - 04.18.2009, 05:30 PM
If your Neu does not have gromets around the power wires coming out of the rear end bell, why not add them? Seemed simple enough. Your thoughts?
04.18.2009, 05:35 PM
Looks good and simple to do. Where do you get those grommets? I have a bunch but can't remember where I got them. I usually just use an extra layer or two of heatshrink.
Snipin_Willy
04.18.2009, 05:38 PM
Gromets came from Lowes. They're over priced and I expect you could get a handful from ebay for much less.
bdebde
That's All Folks!
bdebde's Avatar
04.18.2009, 05:41 PM
That looks real nice. I did a couple layers of heatshrink as well. You do plan on heatshrink on those plugs I hope.
Snipin_Willy
04.18.2009, 05:45 PM
Yeah, already done. I had the idea to stick some grommets in there AFTER I had the connectons done. I unsoldered the bullet connectors, put the grommets in, and put the connectors back on.
George16
Supermaxx
George16's Avatar
04.18.2009, 07:25 PM
Neu put some on mine when I sent it for warranty repair.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
04.18.2009, 07:30 PM
I will have to do the same w/mine! Great idea
rootar
rootar's Avatar
04.18.2009, 11:10 PM
hey william whats the size you used? i need to do this when i wire my truggy tomorrow, and those gromets look better than my split fuel tubing on my wires....
sucks the race got postponed till next sunday but you should have your lipos by then.
Snipin_Willy
04.19.2009, 10:11 AM
Package says 11/32 OD x 1/8 ID
They are a tight fit and take a bit of work to get in. Worlds easier if you have the endbell off, put the grommets in, and lastly put the wires through.
