Traxxas slash brushless
Jason
Exclamation Traxxas slash brushless - 04.18.2009, 10:34 PM
"medusa mr-036-050-3300v2-3f"
anyone using this motor in his slash with a 1/10 mamba max esc on 3s lipo ?
Which setting are the best for this :
Start power : ?
Punch control : ?
Motor timing : ?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.18.2009, 11:28 PM
Do you have the motor and esc yet? I would start with the stock settings and if it needs more/less start power or anything just change it. Everyones setup is different, especially when it comes to little minut things like esc settings.
Jason
04.19.2009, 06:45 PM
I have heard medusa motor prefer high start power and normal motor timing and lowest punch control...
04.19.2009, 07:11 PM
I'm running 4s on the Medusa 36-50-2200 and am using normal timing, highest punch control, and low start power. Works fine for me, and temps are great at the end of a ~40 minute run using a 5Ah pack.
Always Dreamin
04.19.2009, 07:16 PM
I agree with metal. tune it when you get it. that's what i did at least.
Metallover
Metallover's Avatar
04.19.2009, 07:27 PM
What would be a good kv range for 4s? Brian, you said you used 2200, I wonder if the 3300 or in between would work good on 4s? In a Jato?
04.19.2009, 07:28 PM
I'm sure the 3300 will work fine on 4s. I was personally shooting for decent speeds with great runtime.
Metallover
Metallover's Avatar
04.19.2009, 07:32 PM
Was this in a slash? I'm thinking maybe a 36-60-3100 in a jato. That shouldn't run too hot, I would think... It's go the extra length which is always good.
Jason
04.19.2009, 10:36 PM
I tried my feigao 540c 8xl ( 2084kv ) into my slash it work fine geared for around 40mph on 3s the only problem I have no motor heating but the battery drop fast as hell anyone have any idea why ?
Always Dreamin
04.19.2009, 10:42 PM
That motor is made to be run on higher volts. It should be drawing quite a bit... What battery do you have?
Metallover
Metallover's Avatar
04.19.2009, 10:53 PM
the motor is a huge motor for a slash. If you are using a maxamps or smaller capcity pack then you'll have to get a better battery. Nimh won't be able to put out enough for the motor either. That is a 4-5s motor so if you are running a mamba max you could disable the Bec and run 4s...
We will have to know what battery you are running too.
brushlessboy16
brushlessboy16's Avatar
04.19.2009, 11:09 PM
Not true, Lower kv motors draw less curren then equivalent motors of higher Kv.
04.20.2009, 12:16 AM
Yes, it's in a Slash. The Jato weighs roughly the same (especially since I have the FLM tranny and CVDs on the Slash) so what works in one, should work in the other. My jato is running the 4600 combo and works perfect, the same size Medusa is even better.
Jeremy1976
04.20.2009, 09:20 AM
Medusa recommends 8-15 degrees of timing on that motor.
Jason
04.27.2009, 08:17 PM
thanks for the input guys!
now what the best gearing for 3s on this motor on my slash ? :
I run 58/12 on 3s and not so impressed sound like the motor dont have any torque/power... look like got too much top end and not much start/power/acceleration... maybe because jato gearing ? nitro jato are geared stock for ore top end/speed then start/power/acceleration speed I think...
