New 100a reversible car esc on hobbycity
Metallover
RC-Monster Spudgunner
Metallover's Avatar
New 100a reversible car esc on hobbycity - 04.26.2009, 11:16 AM
http://www.hobbycity.com/hobbycity/s...idProduct=8993
Hobby King Brushless Car ESC 100A w/ Reverse
Features:
Full protection feature including low voltage, over-heat, throttle signal lost, startup
protection and self-check.
Compatible with sensorless brushless motor.
Excellent startup performance, linear and quick throttle response.
Supports highest motor speed 240,000RPM(2 poles), 80,000RPM(6 poles) and 40,000(12 poles).
Easy to configure with program card.
System can automatically detect throttle neutral point, and neutral range is adjustable.
Three work modes for different environments.
4 step reverse force adjustment
5 step start force adjustment.
3 step brake force adjustment
5 step drag brake force adjustment,
4 step initial brake force adjustment.
Specification:
Input voltage: 5V-17V (support 2-4S lithium batteries)
Cont. Current: 100A
BEC output: 3A /5.5V (switch)
Size( length X width X high): 47x41x29mm
Weight: 95g
Price - $60 bucks
Stock - 44 on sunday morning
Looks like a mamba max alternative. It has a bec, which might be disable/ble for more power. The bec might also be like the mmm where it doesn't help... I bet this would be pretty nice low-cost alternative in a 2wd or a light 4s buggy setup.
