Go Back   RC-Monster Forums > Support Forums > Team Tekin
RX8 truggy and buggy setups
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
RX8 truggy and buggy setups - 05.01.2009, 11:16 PM
QUick question for all you rx8 owners..what motor/batt/settings are you guys using in your rides? just curious...i ran my 1700kv combo on 5s with stock settings except *10* on drag brake and timing all the way down to "min"....initially the car felt sluggish and had zero POP....but once I changed it to the most aggressive throttle curve all was well....its geared 15/46 and my temps were extra cool...thinking about raising timing to give it more....*get-up* on the throttle.....and BTW the track i run it on is HUGE!....whats your setups?
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
jhautz
jhautz's Avatar
05.02.2009, 12:13 AM
Got the same motor as you and 5s packs also in my XT8 truggy. Ive got 14/46(slipperential) gearing and it was perfect to slightly strong. Actually a bit stronger than my 1515/2.5D setup. I set it up using the recommended settings from Randy Pike with a setting of 20 on the timing. I am going to try 0 this weekend and see if it brings it back to what I am used to. I just don't need the extra power. it just results in wheel spin and makes it harder to turn consistent laps.
to make it...
or break it...
Silent...But Deadly
Snipin_Willy
Snipin_Willy's Avatar
05.02.2009, 12:37 AM
I'm going to try out 16/46 (slipperential) this weekend with a tekno Neu 1515 2.5D. I believe Rootar is the exact same, if he hasn't changed. My battery(s) is a RCM 5200 5s
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.02.2009, 02:36 AM
thats the same batt im using :)
Losi SCTE
MMP/1410 3800kv
Dx3s
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.02.2009, 09:11 AM
I use the same basic setup as JHautz - 1700Kv truggy system on 5s geared 14/slipperential. I didn't dislike my MMM/Neu setup, but this RX8 is the ticket for racing - smoother and more precise by comparison. I use the "2" throttle curve(one step below linear) and 95 punch control setting. I will keep changing settings for experimentation, but I like this setup. :)
TekinTeamMgr
TekinTeamMgr's Avatar
05.02.2009, 11:39 AM
Guys Mike is on the right track. You can use the PC setting to tone down the initial power to keep wheel speed down. It doesn't affect top speed at all.
  Send a message via Yahoo to TekinTeamMgr
RC-Monster Mike
Site Owner
05.02.2009, 11:51 AM
Between the punch control, throttle curves and the Slipperential, power delivery can be infinately tuned to track conditions or user preference. I use minimal punch control just to "take the edge off" in racing - too much and it gets a "muddy" feel in the mid range. I use the throttle curve and expo on my radio to further tune the system power delivery, and adjust the Slipperential for traction control as needed(more slip on a loose track and very little slip in high traction). There is no track that can't be tamed with all the available tuning options. :)
jhautz
jhautz's Avatar
05.02.2009, 01:15 PM
I'm with ya on the throttle curve being a great tool, but rather than do it in the esc, I do it on my radio where I can make quicker changes and do it right from the stand in practice. Its just easier for me that way. I haven't messed with punch control on the RX8 yet cuz I always just ran full punch on my old system, but last week I certainly did utilize the slipperential to "tune" in the initial punch I wanted. I freakin love that thing. On the track I personally think it could be the single best tuning option for power delivery Ive seen yet.
to make it...
or break it...
Silent...But Deadly
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.08.2009, 02:28 AM
jhautz....what tx are you using...im looking to be able to adjust the throttle curve from the tx as well..
Losi SCTE
MMP/1410 3800kv
Dx3s
jhautz
jhautz's Avatar
05.08.2009, 02:33 AM
I'm using the DX3R but any of the high end radios can do it.
to make it...
or break it...
Silent...But Deadly
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.21.2009, 07:21 PM
Update:
OK here's my setup: rc8t rx8 1700kv combo geared 17/46 5s 5200mah RCM lipo
rx8 settings: DB=off, RS=off, BS=50, NW=50,TP=1, VC=5, PC=off
TA=min, CL=off
Here's the track I run it on (haven't raced yet just happy that I can run down a whole lipo without crashing too much :)) http://www.youtube.com/watch?v=hFWTi...eature=related
Its geared for about 45-46mph
With the only WOT section in the beginning quad my run-time was 28min and the temps after the run (it's crazy hot in sacramento right now) were: rx8=4 LEDS, T8=140, Lipo=105 really happy with this setup...it has the punch that i'm used too with the CC2200kv and it runs a lot cooler and more consistent....
Losi SCTE
MMP/1410 3800kv
Dx3s
RBMike
RBMike's Avatar
05.21.2009, 08:00 PM
You got 28 minutes of run time at Prarie city??? That is outstanding.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.21.2009, 08:18 PM
yeup used the timer on the dx3s ...
Losi SCTE
MMP/1410 3800kv
Dx3s
TekinTeamMgr
05.22.2009, 01:27 AM
Nice, I've meaing to check out that track. I'd like a few of us to get together on the same day so we can have a class!
tedo
Vermont, USA
tedo's Avatar
05.22.2009, 09:13 AM
I am running the the RX8 2000 combo in my MBX5T on 4s. It is the most drivable system ever! My gearing is 17/46 with no slipperential. Timing set at 8 degrees, and drag brake is kinda set medium (not sure the exact number, I keep adjusting it at the track) to slow roll in to the corners instead of using brakes. Linear Throttle control also.
So smooth....
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
