Waterproof ESC
alangsam
Waterproof ESC - 05.26.2009, 03:40 PM
Patrick/Joe
How about a waterproof ESC? it sure is nice to be able to hose of the models after a run ala the XL5 and upcoming VXL waterproof.
Seems like the sidewinder would be a perfect candidate?
Byte
05.26.2009, 03:59 PM
^ +1
I also REALLY would like a waterproof ESC from a GOOD company, those ESC's who are waterproof just totally sucks which are now on the market.
lutach
lutach's Avatar
05.26.2009, 04:21 PM
Castle uses conformal coating (I know there was some info on this issue here in the forum) which makes their ESCs kind of water proof.
i only know of the XL5 and EVX2
alangsam
i only know of the XL5 and EVX2 - 05.26.2009, 05:03 PM
Originally Posted by Byte View Post
^ +1
I dont know of any brushless ESC's that are waterproof - the VXL is waterresistant which is close but would prefer something with the programmabiliy of a Castle ESC.
I think the waterproof thing is going to be a much bigger deal and Traxxas is going to push this given their market position. There is an opportunity for an OEM to create a better aftermarket solution.
I dont think this helps much
alangsam
I dont think this helps much - 05.26.2009, 05:04 PM
the issue is that even though they are starting to put some casing around the castle car/truck ESC"s they are too exposed to allow dirt/sand moisture to get in. Its really a pain to clean their ESC's after being on a wet track or just bashing in the mud/dirt.
lutach
lutach's Avatar
05.26.2009, 06:07 PM
So what you guys are really asking for is a sealed ESC.
05.26.2009, 06:12 PM
And what about the motor? That would be just as important IMO, and it's gonna be tough to keep the water from messing up/rusting the bearings and shaft (although they could coat the shaft I suppose). There is potentially a lot of fine dirt suspended in ground water. Personally, if you want to run through water, get a boat, or stick with a cheaper brushed setup.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.26.2009, 06:42 PM
This is why my trail truck stays brushed.
www.cubicle101.com
alangsam
05.26.2009, 07:15 PM
i think it can be done with the motors as well. look at the vxl 3500? you can seal with the bearings and seal the cover thats on it now. its only a matter of time and a little bit of innovation. you can buy sealed lipos, sealed brushed ESC's, waterresistent ESC's, i predict a waterproof VXL within a month.
himalaya
himalaya's Avatar
05.27.2009, 12:06 AM
Absolutely! ever try to look into a used MMM? you can plant corn in it.
If MMM has sealed case like the Hobbywing does, that's a final step closer to perfection.
....What a Blue Sky....
05.27.2009, 12:25 AM
Lrp sold waterproof ai speed controls for brushed motors...
I for one use a tupperware that locks shut and has a rubber seal. I tested it by locking it and placing a brick on it in a bucket of water for the weekend. Come monday it was bone dry. I got one that would fit under the body and hold the rec, lipo and esc. Just had to drill 2 holes in it, one for the servo plug, and another for the motor wires. Used hot glue to seal it from both sides. If you run a sealed can bushed motor (I like titan 23t) drill an 1/8 hole in the can by the brushes that faces straight down when the motor is in the truck. Lets the water drain out, and prolongs the like for the motor. Oiling the bushings with atf also helps.
alangsam
05.29.2009, 06:47 PM
has anybody tried to just open the case and use high temp silicon and then seal all of the openings? I realize that would void the warranty but wouldnt it work?
Unsullied_Spy
Unsullied_Spy's Avatar
05.29.2009, 07:40 PM
+1 to sealed ESCs. I can vouch for the MM's "Water Resistance" though, I've run my Rustler through plenty of snow, completely submerged it in water, and it gets splashed from puddles all the time and it keep on kicking.
