As the usual hobbycity spokesperson, I feel obliged to point out the new stuff at hobby city. I logged in, clicked on new products, and found a page filled with turnigy lipos. They are even cheaper then flightmax packs. A 6s1p 25c 5000mah pack is only $85 as the flightmax equivalent is $100.
The highest c rating on the packs is 25c,,, There are 3,4,5, and 6s 5000mah packs. The 3s is $43, $56, $75, $85 for 6s.... There is also a 3s 5000mah 15c pack for under $35. wow.
A polyquest Pack is new to that I'm excited about. It's the 1600mah 2s pack. It's the best pack for the vendetta series if you're into that kind of thing...
I think this is the same thing has the hobbywing stuff
Turnigy Brushless Car Power System 2350Kv/150A
An extremely powerful brushless system for any 1/5 or 1/8 scale truck, car or buggy.
Equiped with cooling fan and a large surge ESC, this system will greatly increase the power output of any standard or brushed system.
ESC Spec.
Continuous Current: 150A
Burst Current: 1080A
Resistance: 0.0002ohm
Suitable Car: 1/5, 1/8 on and off road.
Battery: 2-6 cells Lipo (6-18 cells NI-xx)
BEC output: 5.75V/3A switch mode buit-in
Motor type: Sensorless and sensored brushless motors
Dimension: 68 x 55 x 45mm
Weight: 150g
Motor Spec.
Model: 3674SL V2.0
Kv: 2350
Scale: 1:8
Max Current: 76Amp
Turns: 9T
Weight: 363g
Diameter: 36mm
Length: 76mm
Shaft length: 15mm
Shaft Diameter: 5mm
Contents:
ESC: 1 x 150A
Motor: 1 x 3674SL (2350Kv) with Cooling Unit
Pinion Gear: 21T
Turnigy Programming Card
Price $149.95 --- Already out of stock
