Need help, shculze 18.97/lehner cogging...
T-Bro
Motors and esc's 4 SALE!!
T-Bro's Avatar
Need help, shculze 18.97/lehner cogging... - 06.07.2009, 12:06 PM
I had to put my shculze 18.97 in my tc3 buggy (lehner 4200, external bec) since I shipped my mgm for updates, and it does some serious cogging before it will start to move. Once it decided to finally start moving it performs like you wouldn't believe. It didn't do this running my Bigmaxximum at all. I hit the gas and it moved! The only difference with the setup is I used a receiver pack plugged into my receiver instead of an external bec. What do you think is the problem?
06.07.2009, 12:21 PM
one of the dip switches on the esc is for timing, it's possibe adjusting this will help.
the schulze 18.97 is known for catching on fire. If you cannot remedy the cogging with timing adjustments I highly suggest you stop using the lehner/schulze combination as I foresee a burnt speed control
there was another member that had terrible cogging with an otherwise stellar lehner motor and a schulze esc, and I don't believe he fixed it.
some components just don't like each other.
Tags
cogging, schulze 18.97
