Hot power cord..
montyjcm
Hot power cord.. - 06.11.2009, 01:53 AM
Hey everybody,
So, I am sorry if this is the wrong section, or if I am being a complete neophyte. But you guys are the most knowledgeable out there.. so here it goes.
I was just charging my lipos a few minutes ago, and I noticed that the power cord to my power supply was hot, very hot actually. I whipped out my little infrared temp gauge, and it read up to 125 degrees! Granted, the emissivity setting on the temp gauge probably wasn't setup correctly to read a thin right, but let's say 120+/-5. This seemed pretty high to me. Especially since everything else in the circuit was relatively cool.
Duh.. my setup: Power Supply: Power Cube- 20 amps at 12v
http://cgi.ebay.com/12-Volt-DC-20-Am...3%3A1|294%3A50
Charger: Turnigy Accucell 8150 (8s, 150w max on the circuit)
Batteries: 2, SPC 8000mah 20c charging in series at 7.0amps (max for the charger)
So.. this setup puts me at about 100 watts for 14.8v * 7amps. Of course thats not considering power loss and the increased power consumption when the packs are closer to full, but this is still under what the power supply can supply.. for lack of a better word.
I should note that the cord only remained hot during the cc part of the charge, not the cv part. The cord is also about 3ft long I believe and made of copper. Perfectly normal looking imo.
So, should I be worried? I have never noticed this before, but then again, I have never bothered to check. This charger/ps combo has worked well for me with about 20 or so charge cycles on it. Could I have a bad wire, creating a lot of resistance?
Thanks for the help, everyone!!
