Losi Brushless buggy tips
Shark413
Shark413's Avatar
Losi Brushless buggy tips - 06.13.2009, 07:44 PM
Been working on and racing my Losi for a while and I have been running brushless for several years and I thought I would share some tips I have applied to my Losi. Many of these tips are common knowledge but I figured may be some of these would be helpful to someone. Please feel free to add your own tips.
http://www.youtube.com/watch?v=BP2be0ztm2k
Buggy in action
Tip #1
According to some, the reason the fan blades break is because small pebbles/rocks get into the ESC thru the top grill. To eliminate/reduce this from happening I took some plastic window screen, cut out a quarter size circle and glued it on top of the ESC grill. Keeps the smaller rocks out and still allows plenty of air flow.
A little dab of silicone sealer or CA glue will hold the mesh in place.
Tip #2
Use small pieces of fuel tube to make small washers, these are placed on the ends of screws to help prevent them from falling off, keeps the threads clean and prevents anything from getting snagged on them.
Tip #3
See picture above, the Losi uses smaller outer hub bearings (for lighter overall weight, but some find the bearings don't last as long and some prefer the extra duability of the standard size bearings. King Headz makes an alloy rear carrier that uses the larger 16x8 standard bearing, Integy also makes alloy carriers that use the larger bearing and is about half the price of the King Headz. Some say Integy quality is suspect but I have been using them on my buggy with no issues, you do have to open the hinge pin hole if you use it on a 2.0 Losi. I run the King Headz on my truggy and they are top notch.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Tips Continued
Shark413
Shark413's Avatar
Tips Continued - 06.13.2009, 07:54 PM
Tip #4
This is an old one but because of the way the shocks rotate they sometimes have a tendancy to unscrew the mounting bolts. The 2.0 buggy uses small set screws to hold the bolt in place, but you can also add a second screw to one of the unused holes to hold the bolt in place. This is the setup on my Losi 2.0 truggy.
Tip #5
Low profile wiring. The stock ESC wires come straight out of the bullets and can interfere with the body on some buggies. But to have them come out at a 90 degree angle just drill out the little hole in the side of the bullet and solder the wired into this hole instead.
Tip #6
Radio antennas can take a beating, the little rubber caps usually don't last very long. A 2.4gig antenna can be much shorter than AM/FM antenna, but they can stil llose there caps. Take some shrink tube and place it over your antenna wire and antenna tube, heat it up and your good to go.
More Tips
Shark413
Shark413's Avatar
More Tips - 06.13.2009, 08:04 PM
Tip #7
Mud guards, these help keep dirt and mud from getting into your shocks, rear hubs, cvd's, a-arms, driveshaft, etc. These can be easily made from some polycarbonate sheet. I bought some online, but you can even use scrap left over from the trimmings off one of your bodies. This one is shaped to clear the wheels on one side and the body on the other.
Tip #8
Traxxas brushless E-revo ESC mount, this is a well made and secure way to hold down your MMM ESC. It mounts to the Losi battery tray very nicely and even has a place for the switch. The mount only cost a few bucks.
Tip #9
The battery wire and ESC power leads can get tangled or rub against the center driveshaft. I made a small lexan piece that is bolted to the center diff top plate and helps keep the wires from getting sucked into the driveshaft.
More Tips
Shark413
Shark413's Avatar
More Tips - 06.13.2009, 08:11 PM
Tip #10
If you use the Losi battery tray this is a must. Add a strip of 3M Dual Lock velcro to the bottom of the tray and to your battery. This and the battery straps will keep the battery from sliding forward under heavy impacts and breaking the front of the tray. Dual Lock is much better for this application because it has better shear strength than regular hook & loop velcro. Dual Lock will not move verticaly (shearing motion) where as hook & loop will give slightly which could cause tray damage.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.13.2009, 08:24 PM
I certaintly appreciate the the side solder action on the bullets, That'll make much tidier wire arrangement. Good thinkin' and Thank You !
Blaz
06.13.2009, 08:45 PM
hey nice tips there going to help me alot!i just have one question what conversion kit should i get for my losi 1.0.Thanks
brushlessboy16
brushlessboy16's Avatar
06.13.2009, 09:37 PM
Losi Battery tray, and Rc-monster motor mount.
stum
06.15.2009, 08:01 AM
Great deals on the tekno v3 8ight 1.0 kits.. way better option iMO and the best motor mount on the market.
himalaya
himalaya's Avatar
06.16.2009, 05:30 AM
Best 8ight building tips ever! I am building my 2.0E and your tips are of great help. Thanks.
....What a Blue Sky....
Shark413
Shark413's Avatar
06.18.2009, 04:05 AM
I am glad this info is useful for some of you. I learned a lot from these forums, the rest from asking questions at the track and a lot of trial and error. I am not saying these are the best solutions, just some ideas that work for me and may work for others.
More Tips:
Losi uses some super strong loctite on the wheel nuts from the factory, and for a good reason. The Losi wheel nuts seem to want to fall off at the worst time (during a race). So I found a couple of things that may help. Here are a couple of sets of Wheels nuts that will fit on the Losi hubs. The red ones are from ThunderTiger and have nylon locking rings in them. The black ones are from HPI and have serrations in them that help hold them on. They are relatively cheap, I use the ThunderTiger Wheel nuts myself and they work great, the nylon will wear out eventually, but like I said they are pretty cheap. Here are the part numbers: TTRPD1865 (ThunderTiger) and HPI87519 (HPI).
Shark413
Shark413's Avatar
06.18.2009, 04:22 AM
Another Tip, well not really a Losi tip but I am using the new Tekin T8 motor in my buggy. The Tekin motor features solder on tabs for connecting the wires, I like this feature a lot. I had problems with some of my Neu motors with the wires failing from vibration where they exited the can. On the older Neu motors the wire exited out of relatively large holes and the wires could rub on the endbell cover or vibrate and cause internal shorts. The tabs eliminate this potential problem area. Some people attach the wires to the rear of the can, this looks cleaner but what I found is that the wires can pull on the tabs when the buggy lands from a jump or hits bumps. The wires don't look very heavy but they are pretty thick, made of copper (heavy) and the force of a 1/8 buggy landing hard can generate a lot of momentum. If you route the wires over the motor can they will be supported by the can and if they do move they pull on the tabs towards the supporting reinforcement board (not away).
Showing how the wires can be mount toward the rear or over the can.
If mounted toward the rear the momentum of the wires can pull the tabs away from the fiberboard support and they may fail.
himalaya
himalaya's Avatar
06.18.2009, 07:01 AM
Shark do you have an idea to support the rear end of the motor? Losi's support fits only Losi's 39mm dia. Xcelorin motor, when use a CC Neu or Tekin(42mm), the Losi support will conflict with the motor can and thus have to be removed, leaving the motor hanging far on the mount. The worse thing is, the mount has only two screws to hold the motor, and the contact area covers only half of the front endbell, the 2 screws will take HUGE force when landing hard, also the screw holes of the front endbell might be stripped. (I was considering to purchase a RCM mount to replace the Losi)
As a temporary solution I applied some A+B epoxy resin mixed with cotton fiber between the rear endbell and the chassis. but when adjusting gear mesh the motor height changes, that drove me nuts.
Do you have an idea to better support the motor while keep the mesh adjustment easy(one of the few major advantage of Losi kit) ? Thanks.
Shark413
Shark413's Avatar
06.18.2009, 04:29 PM
himalaya, I use a modded Losi rear motor support on both my Tekin T8 and CastleNeu motors. I posted a "how to" on another site, I will try to locate the post and if I can't I will look for the pictures and post here. You are correct, with those big heavy motors hanging just by the front endbell, you are putting a lot of stress on the endbell and motor mount.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.18.2009, 04:38 PM
Please do ! I would like to read that as well for my applications. Thanks.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
06.18.2009, 06:19 PM
+1 on the tabs being pulled away from the support wall...i soldered my 1700T8 in my rc8t with the wires going away from teh can and the last solder tab worked its way loose from the support wall...it also popped the rivet holding the tab onto the support....once I get my combo back form tekin i'm definitely soldering the wires OVER the motor...
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
