Will a RCM heatsink keep the end of my Medusa on?
e-mikey
Will a RCM heatsink keep the end of my Medusa on? - 06.17.2009, 04:24 PM
The back of one of my Medusa motors popped off. Will a heatsink keep it from happening again.
Also should I put some sort of glue on it before putting it back together?
Matthew_Armeni
Matthew_Armeni's Avatar
06.17.2009, 05:58 PM
The RC-Monster clamping heatsink will keep the endbell on your motor. If you want to run in the meantime, some slow curing CA should do the trick.
  Send a message via AIM to Matthew_Armeni
scarletboa
scarletboa's Avatar
06.22.2009, 05:41 PM
or JB weld
joeling
joeling's Avatar
07.05.2009, 11:31 AM
I had the same problem. I worry about the bearings.
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
lwracer
07.05.2009, 09:55 PM
I had the same problem i used the heat sink as a clamp for the rest of the day but then sent it off to medusa and they repaired mine.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
07.06.2009, 01:53 AM
Anyone come up with a clever removable solution that will keep the motor in one piece until Mike has finished the medusa specific clamps.
scarletboa
scarletboa's Avatar
07.06.2009, 03:17 AM
duct tape!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
07.06.2009, 08:17 AM
Originally Posted by scarletboa View Post
duct tape!
I suppose theoretically there isn't problem duct tape can't fix so I suppose it would work.
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
08.08.2009, 02:21 AM
hot glue would be fine
what about a c clamp that goes from the motor mount to the back of the motor?
or for that matter, zipties around the length of the can, and then some tape around the round part of the can to hold the zipties in place
or even mounting a piece of aluminum angle stock so that the angle sits up tight against the back of the motor
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
