Is undergearing ever bad?
jocktheglide
Is undergearing ever bad? - 06.19.2009, 11:32 PM
I have a tank savage now it weighs 17lbs or so and I was wondering can I go lower on the pinion due to the increase in weight so not much of a strain on the esc/motor? Its stock 20 pinion and i did run with 25 pinion that comes with it for 3 mins and the fan kicked on which is kinda early it seems packs were cool, motor, esc also to touch. I was thinking 18 tooth pinion to compensate for the weight.
brushlessboy16
brushlessboy16's Avatar
06.19.2009, 11:37 PM
Under gearing can be bad in some situations.
you can drop a few teeth on the pinion just watch temps
06.20.2009, 12:01 AM
Yeah, a little undergeared is fine. Too much and the motor is running relatively unloaded, and that's bad. But I don't think you have to worry much about that driving a 17lb truck unless you gear to 1mph.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.20.2009, 12:02 AM
17lbs, yikes. IMO, you should be geared for about 35mph.
speedracer1129
06.20.2009, 11:39 AM
Temps should be your guide!
jocktheglide
06.20.2009, 11:42 AM
yeah your about close on the estimate (based on my estimate also) its fater than an emaxx on 14 cells they claim 35 or so im claming 40 on this truck with the FAT joes on there its still fast enough for me.
