MMM V3 - random glitching
PBO
RC-Unobtainium
PBO's Avatar
MMM V3 - random glitching - 06.21.2009, 07:39 PM
I have searched for this scenario but I there are so many I hope this may be quicker? This isn't my vehicle...
So it's a Losi 8ight B with the full Tekno conversion (including the clutch), running a V3 with a Neu 1515 1.5F on 5S & 6S, 46/18 for general bashing & it's mated to a Spektrum DX3. There's a second fan installed on the motor
The glitching randomly affects throttle only, lasts up to 10 seconds but may happen several times per battery
Any thoughts or advice?
PS, appologies if this has been answered previously
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
06.21.2009, 08:32 PM
Does this get worse after say 100'? Have you tried....
1. twisting the motor wires and servo wires.
2. disconnect additional fan and see if that is the cause
3. check antenna wire for ANY nicks
4. check placement of esc in regards to the rx
spcpicard
06.22.2009, 10:31 AM
I've seen 3 vehicles do the same thing, it's usually the switch. I would direct wire it first and see if that corrects your problem.
06.22.2009, 05:04 PM
I forgot to put that in my suggestions...thanks for pointing it out
PBO
RC-Unobtainium
PBO's Avatar
06.22.2009, 05:46 PM
Thanks guys, appreciate you taking time to answer...confirms my advice to him also
Losi 8ight-T
