Hey guys, just got my 720i in the mail finally... K, when I go to start a charge, is it balancing as well? I would think so, it's just that I can't access each cells voltage when charging...
Or is the 720i taking good care of me? thanks.
As long as you have the balancing connector connected you should be good to go. You do need to be in balancing charge mode, but the instructions should point you in the right direction.
The mode button should allow you to swap into the balancing screen when you are charging and the up and down keys should allow you to view each cell individually and all of them as a whole.
This info is based on the hope that the 720i works like the 610i...
You would think they could make the menu's more straight forward, with a few extra buttons?
thanks
Once you get used to using a hyperion it gets pretty easy. I still screw up the lipo setup screen, but I just make a bunch of profiles, I do have 2 of the 610i chargers and 2 of the 12310i...
Besides I didn't think you could charge a lipo on a hyperion (newer models) without a balancer connected, I know my 610 won't even start the charge.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
Yah, it says it can't charge without one. It will for an A123 pack however, as far I can see. Is this correct?
Yah, looks like you can ignore it, the manual says otherwise however...
It's left twice, and then up once Johnrob...
Also, why is the charger cutting the current a regular intervals for a couple seconds at a time? Is this normal?
Does this model have cycling feature?
Okay, thanks, I figured that was why. Probably to read cell Ri ?
Oh hey, what should I be charging these Hyperion 25C 6s 4350mah packs at? 2C, or 1C? I can't see anywhere on the website where is mentions charging rate. thanks.
