Got an Lx One real cheap so decided to convert it to BL.
I used a second steering brace mounted on steering posts to make the rear of the buggy more stiff.
I used to Hyper9e battery tray (which is good to hold up to 5s packs)
I used the Traxxas mount to install the Mamba Monster ESC on a Plexiglas plate.
Need to find a better way to locate the receiver's antenna.
Motor is the 2200kv with 15t pinion (stock spur is 48t ??) running on Zippy's 4s 25c 5000mah after 10min the ESC was at 115f, lipo pack was at 95f and motor at 155f ( too hot for me) Should I go with a bigger pinion (16t) to have the motor running cooler ??
Any comments/suggestions are welcome.
