Once You Go Black You never go back....
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
Once You Go Black You never go back.... - 06.27.2009, 10:42 PM
Here is my Mini Revo Blacked out, Dyed the chassis and rockers, Then I sprayed the motor mount, Added some black heat shrink here and there, Then I installed a Mamba micro pro, I hated how the stock one had no settings and breaks where horrible, It runs about the same temperature as the stock VXL Around 140 on 3s with 23/50 gearing and the motor runs a bit behind it at 130ish while the lipos (3s 3200mah) Run 80 degrees. I like how I can run the punch control at like 70% and not have to worry about snapping the Driveshafts off the U-joints are going through diffs ( been there done that already)
Name:	Mini E-revo Black Edition.jpg
ID:	7345   Click image for larger version
Name:	Mini E-revo Black Edition V2.jpg
  Send a message via AIM to Wild YFZ 450
Semi Pro
Semi Pro's Avatar
06.27.2009, 10:53 PM
cool, thats the first blacked out one i have seen
Wild YFZ 450
yfz 450.
06.27.2009, 10:54 PM
Thanks, All I will need now is a Neu motor And ill be set.
06.27.2009, 11:01 PM
Black hitec servo and change the push rods/turnbuckles to titanium - check out lunsford grinder links
Wild YFZ 450
yfz 450.
06.27.2009, 11:05 PM
I have a Hitec 85mg I need to steal from my Mini-t just need to get a new case for it since I cut the tabs to fit in it. I am going to check out the lunsfords, Also going to find some black shock socks and then change the Positive wire on the micro pro to a black wire, then I should be set.
