2s 6.6v A123 reciever batt?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
2s 6.6v A123 reciever batt? - 07.03.2009, 02:14 AM
Hey, I have 2 A123 cells here that have not seen discharge currents in 2 years... I cycled them a few times and they deliver about 2100mah @ 2.5v cut-off (720i)... I am doing some discharge tests on them at 1, 2, and 3 amps discharge. They are all around 3.3volts steady.
So, i ask, is it a good idea to use it as a receiver pack? I know you can get 2s lipo specific servos now, such as the Hitec 7740TH...
http://www.hitecrcd.com/servos/show?name=HS-7940TH
So a 6.6volt pack should be about 200oz/in torque and 0.065 sec @ 60deg.... extremely fast servo.
Anyways, can a Spektrum DX2 receiver handle the extra bit of voltage?
07.03.2009, 02:32 AM
I do not see why not, a fully charged nimh 5 cell can beat 6v...
zeropointbug
Z-Pinch racer
07.03.2009, 03:41 AM
Aight, just making sure.
What do think the runtime would be on it? Have you ever ran Rx batts?
I would like to try this, because I had unexpected shutdowns at the races, and I think it was my BEC doing it.
whitrzac
Can't catch this...
whitrzac's Avatar
07.03.2009, 10:05 AM
I have run the 1100mah ones as RX packs, no problems
zeropointbug
Z-Pinch racer
07.03.2009, 02:12 PM
Awesome thanks, some real experience... I am going to toss the BEC, and try em out.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.03.2009, 02:27 PM
One guy put two LEDs on something to drop the voltage from 6.6v to 6v. I don't know if it's needed, but it's just an idea. A fully charged a123 pack has to be over 7v...
zeropointbug
Z-Pinch racer
07.03.2009, 03:46 PM
~7.1volts off the charger, but for this application, I could just use a lower charging voltage (3.5v) so it's 7.0 volts, then I fairly rapidly drops to 3.3volts/cell or 6.6volts for almost the entire discharge.
Also should be zero electrical noise using a pack, might help with radio reception at distance?
Weights 150 grams, BTW.
Do you guys think the 7940TH is a good racing servo? Running off this pack, it should twist around 200 torque, and 0.065 sec transit. For a Revo.
