Medusa 36-50mm 3300kv questions
iTz Nicholas
Talking Medusa 36-50mm 3300kv questions - 07.05.2009, 11:26 AM
I'm going to get a Medusa 36-50mm 3300kv motor to use in a Hyper STe. On www.medusaproducts.com and they also sell the 36-50mm with one if their heatsinks permanatly attached. It is only a few dollars more so should I get that or get the normal version and use a different heatsink?
Motor Specs
MR-036-050-XXXXV2H-5
** Increased cooling over a slip-on heatsink.
** No air gaps to reduce effectiveness.
* *Permanently attached, will not move or slip.
* *39mm long heatsink, 48mm outside diameter.
"You can kill the revolutionary, but you can't kill the revolution." - Fred Hampton
"The common people suffer when the powerful disagree." - Phaedrus
07.05.2009, 11:34 AM
Normal version and then consider an RCM HS
The stock one will limit mounting options as bonded to motor.
iTz Nicholas
07.05.2009, 12:58 PM
OK. One more thing should I get a Mamba Max or wait for the Mamba Max Pro. I heard it was going to handle 6S but less amps so if I do get the Pro a 4S/2200kv setup would be better right?
07.05.2009, 01:30 PM
Personally, I would just get the regular MM. It will handle up to 4s with an external BEC (should be using an external one over 2s anyway).
iTz Nicholas
07.05.2009, 01:33 PM
OK. Would I be able to use the internal BEC with the 3300kv/3S Combo? I'm SUPER OCD about my wires and adding a external BEC would make it that much harder to organize the wires perfect. I know it sounds stupid...
07.05.2009, 01:36 PM
I hear ya, I don't like a wiring mess either. However, the internal BEC of the MM will heat up on 3s and would be better off with an external unit. Or, it would be a tad big, but I suppose you could use a MMM which has the switching BEC not to mention higher current and voltage rating.
iTz Nicholas
07.06.2009, 09:44 PM
Do you think it would be possible to fit a MMM in there. That would allow me to run a 5S/1900kv setup and then when ever I get a 1/8 truggy I could use the packs in parallel or maybe even series.
Though if I'm going to get a 5S battery and a MMM I could just spend a few $$$ more and get a 1/8 and be done with it...
I really want a 1/8 but because of where I live I I would have to drive onroad 99% of the time. The RC18T is pushing the small areas I have to drive on dirt. I'm getting a job and my license in a few months so I guess I could drive to some places to bash...
07.06.2009, 10:09 PM
Anything is possible with a little creativity, but it will be tight no mateer what. It would be easier if there was an extended chassis.
